Hey guys, following earlier comments on this thread, I fitted the MK7.5 Golf R Muffler to my MY18 Tiguan about 3 months ago with an AWE Switchpath Remote.
We simply angled the tips down (rather than removing the trim) but retained the OEM valves... The hangers are exactly the same, but there is some cutting & extra pipe work required to fit - need to remove the golf resonator which is further back than the Tiguan and fabricate a length to the existing system.
The AWE Switchpath is easy to install too (plug & play), just need to cut off the power connector and wire positive/neutral to the boot accessory socket. Works great to open/close instantly when you want more sound or to keep the wife/neighbours happy early morning!
I’ve got the APR Stage 2 with Down Pipe, so found the system had a lot of “rasp” without being muffled, so we installed a 3” Stainless Resonator directly into the down pipe - this made it far more enjoyable and sounds even better as the system carbons up too!
Valves closed, its subtle without any drone and valves open its deep, loud & sporty... Easily switchable depending on mood and both have a great DSG soundtrack too!
Happy to answer any questions! Cheers!
