Page 23 of 48 FirstFirst ... 13212223242533 ... LastLast
Results 221 to 230 of 479
Thread: Tiguan Exhaust
  1. #221
    Jan 2017
    My experience with having installed a MK7.5 R muffler with valves open is that the first week it droned like a mofo, but then mellowed out a bit after 1 week of driving. It has mellowed out even more now after driving for a couple of months to the point that there is hardly any drone. Try to persevere through the drone for a few months & see how it goes if you fit the muffler....
    Quote Originally Posted by jazzyjames999 View Post
    So no one has successfully installed a method to control the valves. I'll defo need to sort this out as I want to be able to control the hooliganism lol!
    MY18 Tiguan 162TSI, Deep Black Pearl, R-Line, Sunroof, DAP | Ordered 6th Jan 17 | Delivered Nov 17
  2. #222
    Jan 2019
    Good to know, thanks TIG162R. After doing my mods I feel the stock exhaust needs replacing now as it really sounds like crap.
  3. #223
    Aug 2018
    Quote Originally Posted by TIG162R View Post
    Could it be that you have just got used to the drone?
    2018 Allspace 162TSI R Line
  4. #224
    Jan 2017
    No chance, the drone in the first week was deafening, to the point I was thinking of putting the resonator back on. The wife has even noticed that the drone has improved significantly.
    Quote Originally Posted by iDiesel View Post
  5. #225
    Aug 2019
    Brisbane, Queensland, Australia
    Quote Originally Posted by veew View Post
    Got around to doing more comparison audio, hope this gives a greater appreciation of the sound inside and out.
    I noticed that I don't get the DSG upshift farts with launch control. I get it during normal driving, the intensity of the DSG upshift farts are dependent on how heavy the throttle application.
    is this with Valves closed or open?
  6. #226
    Aug 2019
    Thumbs up
    Quote Originally Posted by daz32 View Post
    oh snap! a tiguan R
    Attachment 44764
    anyway.. back on topic; finally got the R muffler fitted and very happy with the result
    MK7 Golf R muffler $100
    Res delete $150
    trim removal DIY
    Muffler retrofit $300 (left the valves closed)
    ...DSG farts at 3k rpm
    Echoing others thoughts- this is how it should come from factory. It looks better and sounds better than stock. If you are considering this, highly recommend
    thanks to twyat1 for taking all my questions and all the others for pioneering this.
    does this setup result in drone?
  7. #227
    Aug 2019
    just want to add, learned that the tips on the 7R muffler are sleeves that can be adjusted/moved.
    i.e. you can stagger the tips or have them straight line - adjust to your hearts desire!
    also means removable for cleaning
    i looked for it but couldnt find it on the tips? any specific area i need to look for the adjustments?
  8. #228
    Sep 2011
    Melbourne, Victoria
    If the R muffler was used then the carbon buildup would have already been there so drone would not get less over time?
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
  9. #229
    Jan 2017
    Quote Originally Posted by INASNT View Post
    Its an MK7.5 R muffler which only had about 1000 kms done on it. I also have the resonator delete. I dont know how or why but it has definitely toned itself down.
  10. #230
    Nov 2013
    AUS
    Quote Originally Posted by FunicleJunichi View Post
    Valves are closed by default on my exhaust.
    No drone whatsoever.
    I've run this setup for a while now, happy with it.
    While I wish I did have a switchable exhaust setup I wouldn't remove the valves as the car would be way too loud in the mornings when I leave for work.
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
