Page 10 of 48 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 479
Thread: Tiguan Exhaust
  1. #91
    Jan 2019
    NSW
    Quote Originally Posted by veew View Post
    Other thing is if you want the exhaust to be like a Golf R + res delete + valves open all the time, you just have the tips welded without the valves as this person did.
    Finally thanks to the others on this thread that helped with going ahead and finding photos of other Tiguans with exhaust mods. Were it going to be tougher to do/more expensive I wouldn't have been able to get the car to being closer to perfection (in my eyes anyway haha).
    Thanks for the informative answers! Congrats on this, the sound and look really sets the rear end off!
    Going to look into this in the next few weeks. I’m currently thinking stock Tiguan res + R muffler (valve delete)
  2. #92
    Feb 2019
    South Africa
    The Golf R exhaust is fitted! I kept the exhaust valve controllers on the tips and these are actually closed in default (as per pics).
    As I have a res delete, the car now sounds like a Golf R with a res delete and exhaust valves closed.
    There is no drone at all and farts on upshift are more pronounced than with the res delete alone.
    I'm happy with the amount of noise, doesn't bother my neighbours and I get to hear the farts.
    Really the Tiguan R-line should sound like this as standard.
    Attachment 43453
    Attachment 43454
    Attachment 43452
    Is this with the Oem downpipe and resonator?
  3. #93
    Nov 2013
    AUS
    Quote Originally Posted by Boosted_GP View Post
    OEM downpipe but have deleted the resonator.
    Quote Originally Posted by daz32 View Post
    fantastic!!
    how did you go with removing the fake trim?
    As per the others, loosen the clips on the inside of the fake exhaust trim and then a rubber mallet hitting the outside of the fake exhaust trim.
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  4. #94
    Jan 2019
    NSW
    Ah cool. So its really just clips to be loosened right? There isn't any screws or wiring attached to it? I'm going to try and remove them myself (to try and prevent any clip breakage) before I hand the keys over to the exhaust folks.
  5. #95
    Nov 2013
    AUS
    Quote Originally Posted by GreyGoose_X View Post
    I would leave it to the exhaust guys. I had a lot of dirt and gunk on the inside of the bumper which they used compressed air to help dislodge. Also the rubber mallet loosened up a whole lot too. You'll need to get it reasonably clean to loosen the clips.
    I was there watching them and advising what other's experience was so they knew what to do with the rubber mallet.
    Tiguan Exhaust-img_2437-jpgTiguan Exhaust-img_2446-jpgTiguan Exhaust-img_2448-jpgTiguan Exhaust-img_2451-jpgTiguan Exhaust-img_2449-jpg
    As you can see, the reversing camera sensor wires above the fake exhaust trim would need to be supported in a higher position.
    Current:
  6. #96
    May 2018
    Brisbane QLD
    You can't see it in your pics but there is a little edge above the exhaust trim on the inside of the bumper. That's where I clipped my wiring.
    Sent from my SM-G975F using Tapatalk
  7. #97
    Jan 2019
    NSW
    Nice, super helpful. And just to clarify with the mallet, it’s hitting the trim from outside inward right? Ie you’re hitting in the direction of the car and not away from the car?
  8. #98
    Loosen the clips first as much as you can. I'd high pressure wash the area first would probably also help to remove as much grit from the clips will make the job easier.
    Nov 2016
    MAPLETON Qld
    Obviously loosen the clips first as much as you can. I'd high pressure wash the area first would probably also help. It's going to be much easier to do it up on a hoist.
    I tried doing it myself, but when you’re as old as me lying on your back, trying to undo clips and bash it out, I gave it away and left it to the exhaust shop.
  10. #100
    Dec 2018
    AU
    I'm confused now.
    Do you hit it from inside the bumper out or the other way around? (i.e. hit from the black plastic side or from the chrome side?)
