Hi Erik, the GTI Clubsport front brakes, the red ones you state, are 340x30 size, which is identical to the OEM of my Tiguan Allspace 2.0 BiTDi 240HP version.
So, it seems that my version with already the "GTI Clubsport front brakes", has the necessary brake hoses that fit directly to the highest "R" version bigger brakes.
That's why when I installed the "R" brakes size 356x34, no further action needed to be done, apart from new calipers + rotors + pads + shields.
Check again your GTI Clubsport front brakes, the red ones you state, are they size 356x34 (as you think) or 340x30 size (as I believe they really are)?
Marios
Στάλθηκε από το M2102J20SG μου χρησιμοποιώντας Tapatalk
Marios, my red calipers are the same as your blue ones.The rotors are the same as yours and not the 340mm version but the 357mm version.My original rotors are the 340mm which will be replaced by the 357mm and the 2 pot calipers.But did you use your original brake hoses from the Tiguan or the R caliper brake hoses?Even the dustshields are bigger and have air vents.
Well, in that case, I'll have to ask my local dealer who fit the kit on my car, if the brake hoses of the R were included in the kit I bought or the existing ones of the car were used.
You'll have to wait till Monday morning mate.
PS: I checked again and the result I'm getting is this: Genuine MQB 340x30mm Clubsport S Front Brake Discs Product code:5Q0615301C
Marios,the only way this makes sence that is that your original calipers were the clubsport ones and mine just the GTI ones.Yours with already the beefier brakehoses and mine with some smaller ones because i definately have to change my old brakehoses.
But still thanks for the info..if you could just let me know on monday..it would be a great help.
Greetz Erik.
Yes, that's exactly my thought too, this is the reason!
The rotors of a clubsport S golf 7 are indeed 340mm and drilled.The golf 8 gti cs as the golf 8R have the 357mm drilled rotors..i believe.
And mine is from 2017 and yours is 2019?
Greetz Erik.
Mine is a 2018 Tiguan Allspace 2.0 BiTDi 7seater.
Well,the calipers and rotors are finally installed.All i needed were the original brake hoses from the 2 pot calipers because of the 12mm banjo bolt.The rear brake hoses from the Tig were a direct bolt on.
IMG]https://www.vwwatercooled.com.au/vwimages/image.php?di=VASO[/IMG]
Well done mate, share with us any pics if you want
- You may not post replies
- You may not edit your posts
Forum Rules
