Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 92
Thread: Tiguan/Allspace Big Brake Kits
  1. #21
    Quote Originally Posted by doc_777 View Post
    mate, i’ll be completely up-front and say I know next to nothing about the ACTUAL upgrade on a current VW - @tigger73 is neck deep in this stuff currently so if I were you i’d listen carefully to his experiences and feedback.
    what I would say however is this - number of pistons is not a reliable indicator of performance. My opinion only - a street car should not need more than a 4 piston caliper if it’s correctly matched to the rest of the braking system. You get the best combination of package size, weight etc.
    with all due respect to the supplier you are dealing with, whether your vehicle is 20 years old or 2 months old is irrelevant - the most important part of the upgrade you are considering is whether your current master cylinder will push sufficient fluid volume relative to the volume of the replacement calipers. I don’t pretend to be an expert in such things, I just know how wrong it can all go. If he’s telling you (and importantly, users like tigger who are actually undertaking this process) that the master cylinder is up to the task - i’ve got no reason to question it.
    I agree that going to a a 4 pot set-up with some good pads would be more than sufficient for everyday road use.
    After a bit more driving (since picking up yesterday) the pads are beginning to bite a bit better and take-up point is almost back to "normal". There may be a fraction bit more pedal travel but that is compensated for by how these things haul you up. Seriously you have to be concerned about people tailgating you as if you jump on these they'll have no chance of pulling up without taking out your rear bumper.
    I know there's a few more people with Golf R's with 6 pot set-ups and Tig has the same BMC so I wouldn't be too concerned about it not being up to the task. Probably more a question of whether they are a necessary upgrade. If you were tracking/tarmac rally then I'd say they'd be worth it. But I'd say start with some performance street pads first before spending a decent chunk of change on a BBK.
    Pics of said brakes for reference:
    Tiguan/Allspace Big Brake Kits-alcon-bbk-jpg
    Tiguan/Allspace Big Brake Kits-img_4921-jpg
    May 2019
    Melbourne, Vic
    Thanks guys, I do appreciate all your advise and I understand what your talking about. I actually had my concerns going with the 6 pots and I can honestly say that these were recommended to me by them for street/track. I think he was trying to upsale me something that was an overkill!
    I've only ever used 6 pots (Willwood) on an old modified Ford Escort MK2 RS2000 back in the UK (many moons ago) and had to have the pedal box modified with individual bias brake cylinders for front and rears rotors + dual clutch setup. The OEM setup was for 2 pot front & drums rear. These new mechanics has greatly changed since then with greater efficiency and better feel but I was still unsure if it'll work.
    Anyway I am now leaning towards the 4 pot setup as I believe it's more what I was originally thinking of using. Which is daily street/freeway but would like to run it on a track day or up the strip, time permitting and when the wife will allow. Anyway just for fun and a rush...
    I know just upgrading the pads would save a great deal $$$$ but I'm after that extra bite, responsiveness nature, weight reduction and a better appearance through the wheels. Not to mention it being something different to every other Tig around... Down the track I may seek more power, engine strengthened etc who knows...
    Anyway my question - What are the original calipers on the Tiguan/Golf R's?
    After much googling, I can't find much information if they are 1 large piston or 2 piston for fronts, rear is 1 piston I think judging by images? I think the rotor size Front 340x32 & Rear 312x12?
    I am thinking of either of these - Racingline Performance Monoblock Brake Upgrade - MK7 R/GTI, S3, VRS - Harding Performance or CAR98COM/VE355MM | Alcon CAR98 Caliper Brake Kit what's your thoughts?
    2018 Tiguan Allspace R-Line - Platinum Grey Metallic
    Stage 3 - Snail IS38 Hybrid Turbo - Etuners Motorsport - 265.5awkw's
  4. #24
    Quote Originally Posted by Razor80 View Post
    Tiguan/Allspace 162 are front: 340x30 and rear: 300 x 12
    Golf R are front: 340x30 and rear: 310x22
    The calipers on the Golf R are different though. Pretty sure both are 2 pot (1 larger piston each side).
    The Racingline are only 345mm discs so the actual braking performance is not significantly better than stock (marginal), however they do claim that repeated braking is greatly improved in terms of repeated stops.
    The Alcon 4 pots are 355mm so you probably would notice a slight improvmenet with these and again it's going to be the repeated applications where the aftermarket kit is going to be an advantage.
    This probably moreso comes down to the pads and how well the pads are able to cope with high temperatures without breaking down.
    May 2019
    Melbourne, Vic
    Thanks for clearing that up - Interesting why they put a skinner rotor on a heavier car! Or are the Tiguan's meant to be stock standard.
    So in saying this B/D was suggesting this if I was upgrading the rear rotors and pad https://brakesdirect.com.au/aus/f2d-350-22-aar-r-forza-2-piece-brake-disc-350mm-upgrade-including-red-carrier-right.html so this wouldn't fit if this is much thicker or is that what the carrier is for the adaption?
    I found these guys that have the Wilwoods -
    and these guys have the Brembo or AP Racing -
    Race Brakes Sydney | Brakes so will get some pricing and see what they can do. Is there a maximum rotor size on the 4 piston setup?
  6. #26
    May 2019
    Melbourne, Vic
    *Tried to edit my comment above but crashed*
    So in saying this B/D was suggesting this if I was upgrading the rear rotors and pad F2D.350.22.AAR-R | Forza 2 Piece Brake Disc 350mm Upgrade Including RED Carrier (Right) so this wouldn't fit if this is much thicker or is that what the carrier is for the adaption?
  7. #27
    To be honest If you're not going to go much bigger than the 340mm stock front brakes you may as well just upgrade the pads/rotors and be done with it. It really depends what you're chasing. 2 piece rotors will be lighter than the stock set-up so will reduce the rotating mass which is always a good thing. The stock calipers are pretty damn heavy too as they're cast stainless and weigh a ton. That being said you're driving an SUV so if you were really concerned about weight you'd be driving a hot hatch.
    The 1 off braking performance between a 340mm stock set-up and a 345mm 4 pot you probably wouldn't notice. You'll pay a fair bit to change them over which is why I'd suggest just doing a pad/rotor change (optional) and paint them.
    Unless you're going to significantly larger rotors you won't be achieving much in terms of better braking because you need the larger diameter and bigger contact area to make a noticeable difference.
    So I'd either hunt around for some second-hand 4 pots if you really want to change the calipers or save up for a 380mm 6 pot set-up.
    Even if you're doing some happy laps on the track a pad upgrade is probably all you really need.
    The other thing to consider (and it's more of an issue on the Golfs) is if the larger brake calipers will fit under your wheels. I know a few people that have tried (and failed) to fit BBK's on Golfs and then had to fit spacers/got into problems with wheel poke and then had to get new wheels to fix the poke problem. It's less of an issue on the Tiguan due to the car running 10+mm more offset than Golf but something to keep in mind.
    Mar 2019
    considering the stock brakes will trigger the ABS when the tyres start to slip, surely the tyres are the limiting factor for stopping the car....
  9. #29
    Quote Originally Posted by MickyD View Post
    Actually the brakes make a decent difference. ABS only really kicks in at lower speeds but the brakes will wash off the vast majority before they "lock":
    Tiguan/Allspace Big Brake Kits-stopping-distance-png
    May 2019
    Melbourne, Vic
    I am after less weight and larger rotating mass to stop the car without too much deterioration from the standard rotors getting too hot thus reduced braking capabilities. The standard brakes always weigh a ton and it's performance maybe fine and ideal for your standard vehicle but in a couple of weeks time mine will not.
    I know it's not a hot hatch (ATM far from it) but who's saying it can't be bigger one, Well in an SUV form anyway haha... Besides this, the wheels (changing later) are blooming heavy but having a small reduction from the upgraded brakes will greatly help the suspension.
    This is really twisting my brains! I am really contemplating to go the 6 pot avenue, judging by what you are saying and the fact there's not much in actual surface area for the 4 pots price point to be actually beneficial, especially when there's only $400 between the two kits. Just thinking like BMW, Audi, Merc etc, all use a better brake system based on the their higher spec versions and probably to enhance it's looks.
    Anyway I have the funds (well budget) to get this done as I just want it done properly. I'll be kicking myself if (shortly) down the track if they'll not meeting my expectations, that I'll have to fork out even more cash that could be put towards something else or even a holiday for my family. I just want to enjoy my car and feel safe.
