Originally Posted by
doc_777
Fitting larger capacity calipers won’t help you if the master cylinder isn’t up to the task. Larger calipers (greats number of pistons, larger piston volume) require a larger amount of fluid to be pumped to them to result in the same clamping pressure. There will be slight variations due to a larger swept area producing greater friction with less clamping pressure, but unless the factory master cylinder is up to the task you’re asking of it, then you’re going to require higher pedal pressure to achieve the same clamping pressure (you have to push the pedal harder than you do now to get the same stopping power), and ultimate braking capacity could quite possibly be reduced.
Physical fit is only one of the factors to consider. Arguably the most important one - compatibility of the replacement calipers with the factory master cylinder - is the one most often overlooked.
Thanks doc_777. This is what I am concerned about whether the standard hydraulic system will be adequate once fronts are upgraded. Will the rears loose pressure or vice versa?
Ive spoken to George at Alcon and he's positive these will be fine on the MQB standard system. So now im confused!
2018 Tiguan Allspace R-Line - Platinum Grey Metallic
Stage 3 - Snail IS38 Hybrid Turbo - Etuners Motorsport - 265.5awkw's
