Big Brakes - Allspace R-Line
Quote:
Originally Posted by
Razor80
By the looks of the pistons they look like there staggered in size rather then the same size for all six. I'm guessing this is the help with the BMC with fluid pressure?
Not 100% sure but I’ve seen it on a few 6 pot brakes. Probably because this gives more even wear and best performance/feel??
Razor80
Hopefully once you've bleed them and bedded them in the pedal feel will improve. Are you keeping your rears stock? I'm not sure whether to change the pads and leave the standard rotors to gain a better response from them.
I’ll possibly upgrade the rears with pads/rotors at a later stage. Pads can give you better initial bite if that’s what you’re after. Also some people change to ATE ceramics for less dust.
Razor80
Btw - Howlong did your order take from ordering to being delivered?
These are normally around 4 weeks for the calipers plus a few days for painting. All the rotors/pads/hats etc are off he shelf items locally.
My workshop had these from a cancelled customer order so I was able to pick them up and get fitted without having to wait.
