Assuming that control module supports it as you said yes needs to be correctly coded and adapted then calibrated.
Sent from my SM-G960F using Tapatalk
Hi guys,
I am new to this forum. I have a Tiguan Allspace MY2019 in India. This is an imported unit made in Mexico. The car comes with Cruise control, Front Assist and Lane assist as standard. It also has the below mentioned Radar & Camera hardware.
I was wondering if enabling ACC and TJA was possible through VCDS or ODIS to enable it. My dealer said he’s cool if I use the tool at his workshop but he doesn’t know how to do it himself as ACC doesn’t come on VW cars in India.
Can the pros on this thread shed any light on how I can go about this.
Address 13: Auto Dist. Reg (J42 Labels:. 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 320460C358FF8728749C810500408700000000000000000004
Shop #: WSC 00066 790 00454
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: N/A
VCID: 43859048CA72A857FA-8016
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_ACCMRRCONTIVW376" ()
No fault code found.
Address A5: Frt Sens. Drv. Assist
Control Module Part Number: 3Q0 980 654 L
Component and/or Version: MQB_B_MFK H12 0610
Software Coding: 000307060102040100021344C150A90084000E20000000
Work Shop Code: WSC 00066
VCID: 408F9F44DB64B34FE7-8014
Advanced Identification/FAZIT
Serial number: 07101912K23645
Identification: BOJ-050
Date: 07.10.19
Manufacturer number: 2120
Test stand number: 3645
Flash Status
Programming Attempts(application): 0/0/0/1/1/1
Programming Attempts(data): 1
Successful Attempts(data): 1
Flash Date: 00.01.01
Flash Tool Code(data): 00454 790 00066
Misc.
Hardware number: 3Q0 980 654 A
Workshop System Name: R242
Equipment/PR Code: 00000000000001FDD2A1E0D5
Dataset Number: V03935311DJ
Dataset Version: 0001
ASAM Dataset: EV_FMKBoschMQBB
ASAM Dataset Revision: 002041
VCDS Info:
Labels: 3Q0-980-65X-A5.clb
ROD: ERROR - EV_FMKBoschMQBB 002041 ()
No you can't use vcp and or vcds.
Yes it's possible but no your dealer cannot help.
Hi, I do have a Tiguan 2018 Trendline. I’ve already rang the dealership to setup ACC but heard no. The vehicle comes with CC and speed limiter as well as front and lane assist but not the ACC. appreciate if someone can suggest if/how it can be done (I’m based in Aus)
