Results 1 to 6 of 6
Thread: Tiguan 2020 Mid-Life Update
    I know this is getting in early but there's a few pictures floating around of the mid-life update that will be coming out for the Tiguan (likely) in 2020.
    GTE concept with new front end:
    Tiguan 2020 Mid-Life Update-vw-tiguan-frankfurt-3-jpg
    Tiguan 2020 Mid-Life Update-volkswagen-tiguan-ph-16-jpg
    And some spy shot of a new front end for the standard Tiguan:
    Tiguan 2020 Mid-Life Update-589191754d44d8fad4981c90ff33c25d-jpg
    Tiguan 2020 Mid-Life Update-tiguan-2019-review-2019-vw-tiguan-2019-volkswagen-tiguan-auto-supercars-tiguan-2019-1024x626-jpg
    You would anticipate the GTE concept might be something resembling an R-Line front bar. They definitely need to clean up that overly 'heavy' design and that looks like a solid improvement.
    Although your "standard" spy shot has Mk7 Golf R/R-Line overtones to it's shape/design.
    Jun 2014
    sydney
    i think the bottom 2 are the touareg mk3 under test. With camouflage/covers over the new front grill
    MY18 Golf Alltrack 135tdi - DA pack, SL pack without sunroof, Info pack : tungsten silver
    Quote Originally Posted by limiteded View Post
    I think you could be right here. On closer inspection there is a cover over the lower section of the upper grille (between the number plate and the badge). The wheels/car also does look heavier too.
    I like the GTE design front bar. I'd have it on my car. I agree that the current R-line is a bit heavy on the styling and doesn't necessarily balance/blend well with the rest of the car.
    That blue GTE would be spot on - right front bar, right colour and right wheels eh.
    Far sportier/better looking than existing R-Line set-up. I absolutely suspect they will fix that issue on the FL.
