for me, its most obvious on smooth roads, sit at around 2500rpm then floor it .under the same situation, but going around a corner, with the steering wheel is not centred then it won't do it. the vibration is sensitive to low down torque so up around 5-6000 amp its not there......i work in the new car area and drove a new triton and under acceleration , the tail shaft vibrates . also, my old hq kingswood did this. The Tig on the other hand, should be super smooth at all times, like my 2015 r line i traded on this 162 r line...i will keep you posted.
