Page 71 of 84 FirstFirst ... 2161697071727381 ... LastLast
Results 701 to 710 of 833
Thread: Tigger73's 162TSI Sportline
  1. #701
    Quote Originally Posted by veew View Post
    When are you fitting the parts?
    Hopefully get the sway bar installed over the weekend. I'll also test out the towels too next wash
    Sway bar installed. Went for a quick run around the block and retightened the bolts. Certainly corners a lot flatter and initial impressions is that there’s significantly less understeer which is nice.
    Nov 2013
    AUS
    That sounds awesome! I'm going to need to pull my finger out and just do it.
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  4. #704
    Yeah I haven't been for a run through the hills yet but just on the streets it feels a lot tighter. Really looking forward to testing out the new sway bar and tyres. For the $ it's a pretty big change in the handling of the car.
    Glad to read that it fitted up all ok. Will be on my shopping list now, best and underated bang for buck handling upgrade.
  6. #706
    Jun 2020
    How much does it cost and is it easy to install?
  7. #707
    Quote Originally Posted by vdubbed12 View Post
    Here's the kit I bought: SuperPro Rear 24mm Adjustable Swaybar & Link Kit Fits Audi VWRC0052RZ-24KIT
    I bought it when there was a 20% off sale for SuperPro, however Sparesbox has got 15% off until the end of the month site-wide. You may find it cheaper elsewhere. There's a number of other options for Mk7 Golf R (Whiteline, H&R, etc) and they should all fit/work.
    In terms of fitting it wasn't too bad. I did it on the drive on jack stands in around an hour and a half. Had a bit of a struggle getting the end links seated into the frame. It's all pretty basic - 8 bolts to do everything. Would have been easier to drop the exhaust but managed to do get the bar in/out with it still bolted up.
    Jun 2020
    Thanks for the heads up tigger73. I was just looking up the site as well and couldn’t find the one you got. I’ll have a look at the link. H&R ones are like $900.
    MY20 Tiguan Allspace Black - R-Line, S&V, Pano roof
    MY11 MK6 GTI Black - Leather, Sunroof etc.
    MY17 MK7 Golf 92 TSI
    MY18 Mazda CX-9 Touring AWD (For sale)
  9. #709
    They don't list it for the Tiguan. You have to select Mk7 R. Or just put it the part number. and yes the H&R ones are expensive. I couldn't justify spending more than I did for effectively the same thing.
    Also I didn't want to go too big (i.e 25-26mm) in terms of the upgrade as then I'd probably have to do the front as well to match and that's a much bigger job in terms of the installation.
    The stock bar is 22mm and pretty sure it's hollow too as the 24mm SuperPro bar is noticeably heavier.
    Jun 2020
    Thanks for the helpful tips, I see what you mean. It sounds like a very good upgrade for the money and the way to go.
