They don't list it for the Tiguan. You have to select Mk7 R. Or just put it the part number. and yes the H&R ones are expensive. I couldn't justify spending more than I did for effectively the same thing.
Also I didn't want to go too big (i.e 25-26mm) in terms of the upgrade as then I'd probably have to do the front as well to match and that's a much bigger job in terms of the installation.
The stock bar is 22mm and pretty sure it's hollow too as the 24mm SuperPro bar is noticeably heavier.
