Page 68 of 84 FirstFirst ... 1858666768697078 ... LastLast
Results 671 to 680 of 833
Thread: Tigger73's 162TSI Sportline
  1. #671
    Nov 2016
    MAPLETON Qld
    24mm with end links.
    These will definitely fit our Tigs? SuperPro and Sparesbox keep saying they won’t.
  2. #672
    Quote Originally Posted by Hole46 View Post
    I’ll report back but from all indications the Mk7 R rear sway bars are direct bolt on for the Tiguan.
    The problem is they’re not listed on any of the manufacturers sites as compatible as they probably haven’t tested it. Not too many Tiguan owners would be looking to do the upgrade.
    Keen to see how you go with the sway bar fitment and your views on handling. I find my standard Tig's handling to be very average, even awkward especially turning through roundabouts.
  4. #674
    Quote Originally Posted by AxlRose View Post
    Mine isn’t too bad but I do have the adaptive dampers and Eibach springs which firm things up. This will hopefully reduce the body roll a bit more.
    I’m not expecting miracles but it’ll hopefully tighten things up a bit.
    Are you sure you got a 24mm bar? I only found superpro 22mm solid 2 point adjustable for the rear? Stock bar is 22mm hollow I believe but the solid bar and links should make a big improvement.
  6. #676
    Here’s what I ordered:
    SuperPro Rear 24mm Adjustable Swaybar & Link Kit Fits Audi VW RC0052RZ-24KIT
    9995-RC0052RZ-24KIT
    SuperPro Rear 24mm Adjustable Swaybar & Link Kit Fits Audi VW RC0052RZ-24KIT | Sparesbox
    Nov 2016
    MAPLETON Qld
    9995-RC0052RZ-24KIT
    I ordered exactly the same this morning.
  8. #678
    There may be 2 sway bars with end links for sale shortly Tigger73's 162TSI SportlineTigger73's 162TSI SportlineTigger73's 162TSI Sportline
    Nov 2016
    MAPLETON Qld
  10. #680
    Nov 2016
    MAPLETON Qld
    She’ll be right Tigger73's 162TSI Sportline
