![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
tigger73
The DSG tune is reasonable in terms of remapping the shift points, however it still requires a few tweaks to get a good launch. I've tried a couple of launches earlier today and it's only 0.1s faster using a launch compared to mashing the throttle in M mode and shifting manually. Usually a "good" launch will gain around a second (may be less at the pointy end of 4 sec 0-100's).
This file is more potent than your original file, possibly a little more in it with some custom dyno time and BP ultimate tuning.
Is there a bit of a torque kick at 4K rpm?
How did you go with the gtech measurements for 0-100?
VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
