Originally Posted by
tigger73
Dyno results for the low boost file above (blue line). This is around 21psi and is 205-210kwaw on a “normal” dyno. This particular dyno reads about 20kwaw low.
You can see that the turbo comes on boost and is able to hold it all the way through to redline.
The red curve above shows the second file that was put in and the ECU protection cutting in just as it was ramping up. Unfortunately we ran into closing time for the dyno centre/workshop (Friday night) so ended up with a revised file and road logging only.
New file is quicker than the low boost file but these a few more revisions required before we’ll call it “done”.
The mainline dyno is a heart breaker dyno...
Not a bad result, but was expecting significantly more from the 475HP TTE and HPFP. Did the tuner say there was more in it ?
As a comparison you should do another gtech run when it’s dry....
VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
