Quote Originally Posted by Melbourne_Tiggy View Post
Does the TCU tune have adjustable LC ie you can dial in higher RPM depending on amount of throttle- mine is set to 3000 at 1/2 throttle, 3500 at full throttle and 4000 with kick down. So depending on the conditions you can pick a suitable launch RPM.
What sort of power do you think you’re running? 250 kw atw?
Not sure on adjustable launch RPM may have to try that out later.
I’m nowhere near 250kwaw at the moment. I would say more like ~200 is my guess.
There’s 3-4 psi more boost to put in and each psi will give you 10kwaw give it take. Plus the fact I’m running a low spec/grade 98 fuel means I can’t run anywhere near as aggressive timing.
