Page 47 of 84 FirstFirst ... 37454647484957 ... LastLast
Results 461 to 470 of 833
Thread: Tigger73's 162TSI Sportline
  1. #461
    May 2018
    Brisbane QLD
    What DP are you running. Generally speaking most aftermarket DP have been the source of rattles as or needs to be modified to fit. After my hangers were adjusted again the rattle went away.
    Sent from my SM-G975F using Tapatalk
  2. #462
    Quote Originally Posted by twyat1 View Post
    RD Technik Mk7 R DP fits better on the Tig than on the Golf! Actually needed to shorten the catback section f the stock exhaust by 30mm to get proper fitment - probably because of the reducer. Also spoke to the workshop and they said most likely a small exhaust leak but will get it back there in the week after Easter/Anzac for round 2.
    I know a couple of others have also experienced small rattles after install so I'm not too worried.
    Most downpipes will have some sort of adjustment required, either at the turbo clamp, exhaust hangers, cat/midpipe clamp or reducer. The APR downpipe fits well without the need for shortening the OEM exhaust/cat back. I did have a rattle near the cat/midpipe clamp that needed tightening, but I think your cat is situated in the OEM position....as you say likely to be some part of the heat shield that needs to be bent away from the pipe.
    VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
  4. #464
    Maybe cut off the slip joiner and get a set of self-locating v-bands, 1x step down reducer & an exhaust bellow.
    I know it's not "Euro" spec, but those slip joiners on Euro cars are a nightmare and I hate them. I've been under the Tiguan a few times and itching to mod it, but the wife said to finish off the R33 before I touch her car haha
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
  5. #465
    OK just spent a bit of time updating the first page (first few posts) with progress to date. I'll post up a full build list in the first post shortly also.
    Aug 2018
    Great update. She’s certainly coming along.
    2018 Allspace 162TSI R Line
  7. #467
    Quote Originally Posted by iDiesel View Post
    Thanks!
    I've put together the mod list. It's seemed to have grown a bit more than what I thought...
    BASE CAR
    2017 Tiguan 162TSI Sportline, Crystal Black, Sunroof
    MODIFICATIONS
    HRE FF15 20x9 ET35
    Eibach Pro-Kit Lowering Springs
    TTE475 Hybrid IS38 Turbo
    RD Technik Stage 3 ECU Tune (base map)
    RD Technik Stage 3 DSG Software (to be installed)
    RD Technik 3" DP (Mk7 R spec)
    R600 Intake
    Racingline Silicon Intake Pipe
    Wagner MQB Intercooler
    Leyo Turbo Muffler Delete
    Leyo High Flow Turbo Inlet Pipe
    VIS HPFP (to be installed)
    034 Motorsport Billet Aluminium MQB Dogbone Mount Insert
    Full Size Spare
    Nova EVO Ceramic Coat
    Forever Black bumpers
    Jul 2017
    Hi Tigger72
    I you looking some serious very light high performance tyre on wet and dry .Will make your tig to start as rabbit , than I can recommended you try new Conti premium contact 6 .They are lighter at least 1kg per tyre than any other brand tyre in this cat, and have almost all better performance in all aspect than Conti sport5 https://blobs.continental-tires.com/...act-6-data.pdf .some vide review Goodyear Eagle F1 Asymmetric 5 VS Continental PremiumContact 6 Test - Tyre Reviews
    Price here in AU can be find also really cheap for this performances offered.
  9. #469
    Thanks Cameleon. I will be looking at tyres soon(ish). I do a fair few km in my cars so good wear is also a consideration. Ideally I'd like to get 35-40,000km out of a set. I know that's not always possible, however I'd be prepared to sacrifice a little in terms of performance if I can get another 10,000km out of a set the tyres. Ideal world I'd have a long life performance tyre which is good in wet and dry but that combination is often hard to achieve.
    Jul 2017
    I know previous usig Conti , from ContiSport5 was wearing very fast almost finish at 20k! but this one at least on 4wd tig I had 25k and still at least left 15k for front and maybe 20k for rear left to use .But I don't put this car hard and I am not racig, but I never notice wheel spin with this tyre regardless how wet is or fast cornering or road condition. However this is not tyres for everyone if you don't like soft fill tyre. It is so light and so soft easy to move around with one finger on steering . When first time you come to this tyre you will be thinking like is balloon not tyre And need some get used , as is very very light and sensitive tyre on steering input. Again because is just incredible light ( 21kg only on 18 inch sportline Audi wheel in 235/55R18 for compare on some wheel Bridgestone H/P sport tyre with even lower profile /235/50/R18 was 24.3kg so saved almost 3.5kg per wheel!
    In beginning I didn't like at all this tyre was bit scare at high speed , till I didt find correct pressure for this tyre , but after get some used on lightness and adapted on precise sensitive control steering input is just amazing ultra light grip tyre ,very comfortable and noise is also minimal.
