Originally Posted by
tigger73
RD Technik Mk7 R DP fits better on the Tig than on the Golf! Actually needed to shorten the catback section f the stock exhaust by 30mm to get proper fitment - probably because of the reducer. Also spoke to the workshop and they said most likely a small exhaust leak but will get it back there in the week after Easter/Anzac for round 2.
I know a couple of others have also experienced small rattles after install so I'm not too worried.
Most downpipes will have some sort of adjustment required, either at the turbo clamp, exhaust hangers, cat/midpipe clamp or reducer. The APR downpipe fits well without the need for shortening the OEM exhaust/cat back. I did have a rattle near the cat/midpipe clamp that needed tightening, but I think your cat is situated in the OEM position....as you say likely to be some part of the heat shield that needs to be bent away from the pipe.
VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
