Is that a golf R turbo modified for increased flow?
Delivery!!!
Tiguan 162tsi Sportline
what are you expecting at the wheels after this is installed, Australia's most powerful Tiguan?
** ah just reading back through you mentioned looking for 250kw atw and sub 4's, but questioned if possible to do it whilst maintaining daily driveability. TTE reckon their turbo's spool up quickly, be interested to hear how it drives following installation
Yes should be mid 3’s 0-100 but will need some decent tyres to get traction off the line.
I’m hopeful of 250-260kwaw but we’ll see. And reason for going TTE475 was that it spools quickly - peak torque around 3,000rpm all the way to redline.
TTE do make a 535 but this is a bit more laggy and as soon as you start pushing 500+ you really need to build the engine.
So I’m looking to make good power but not push the envelope too much to the point you start breaking things... at least that’s the plan.
Wouldn't say "stock" housing, as you can clearly see that the housing has been machined to fit a larger compressor wheel
Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
3000rpm still seems higher than it should for peak torque to come on even with the hybrid turbo. Factory golf r with stock is38 reaches peak torque from 1850rpm at the engine. You would think this shouldn't change (rpm for peak output) when measuring at the wheels but all the dyno charts do not reflect this.
Have you had the new turbo installed yet?
