Page 39 of 84 FirstFirst ... 29373839404149 ... LastLast
Results 381 to 390 of 833
Thread: Tigger73's 162TSI Sportline
  1. #381
    Delivery!!!
    May 2018
    Is that a golf R turbo modified for increased flow?
    Tiguan 162tsi Sportline
  3. #383
    Quote Originally Posted by Janus77 View Post
    Yes it’s a TTE475 so hybrid IS38 uses the stock IS38 housing but all new internals.
    May 2018
    what are you expecting at the wheels after this is installed, Australia's most powerful Tiguan?
    ** ah just reading back through you mentioned looking for 250kw atw and sub 4's, but questioned if possible to do it whilst maintaining daily driveability. TTE reckon their turbo's spool up quickly, be interested to hear how it drives following installation
  5. #385
    Yes should be mid 3’s 0-100 but will need some decent tyres to get traction off the line.
    I’m hopeful of 250-260kwaw but we’ll see. And reason for going TTE475 was that it spools quickly - peak torque around 3,000rpm all the way to redline.
    TTE do make a 535 but this is a bit more laggy and as soon as you start pushing 500+ you really need to build the engine.
    So I’m looking to make good power but not push the envelope too much to the point you start breaking things... at least that’s the plan.
    Wouldn't say "stock" housing, as you can clearly see that the housing has been machined to fit a larger compressor wheel
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
  7. #387
    Dec 2018
    AU
    3000rpm still seems higher than it should for peak torque to come on even with the hybrid turbo. Factory golf r with stock is38 reaches peak torque from 1850rpm at the engine. You would think this shouldn't change (rpm for peak output) when measuring at the wheels but all the dyno charts do not reflect this.
  8. #388
    May 2018
    Have you had the new turbo installed yet?
  9. #389
    Quote Originally Posted by Dose Pipe Sutututu View Post
    Ok then based off the stock housing so all the ports/connections are the same. Straight swap for stock turbo so there’s no new lines/connectors required.
    Quote Originally Posted by Psych101 View Post
    I think you’ll find the IS38 spools up/hits boost/Peake torque at around 2900rpm:
