Ran some timed 0-100’s this morning.
Was quite surprised with the results:
So that’s 0.4sec off the stock 0-100 time just from an intake!
Wow, makes me want to go out and hack away the snow guard right now! Not much snow here in Sydney.
I can’t remember exactly what temps the stock run was done at but it certainly wasn’t a hot day. This morning was about 22 deg C so would have been max 10 deg C between the 2 - probably less.
Yes. Stock run was using same device and ran both directions on same road to check/verify.
I was surprised at the difference. Most times intake just makes noise and no measurable performance gains but this is massive. I was kind of expecting 0.1s max but 0.4s is a significant gain.
I suspect the snow grate delete on the stock intake would give a little more at top end too.
Plus intake upgrade keeps warranty intact
And for those who just want to remove the snow grate, I just did it. Took less than 5 minutes, lifted straight out, and didn't even get my hands dirty. I have no way of knowing if that made any difference, but I figured it couldn't hurt![]()
From my testing I think you may get a modest increase. If you also installed a high flow panel filter you’d probably be able to get a measurable difference.
I think the filter element plays a decent part as well as the more direct flow path with the Racingline intake.
Confirming a moderate increase. Snow grate removal was tested and there was a 3% increase in CFM:
Mk7 GTI Stock Airbox Snow Guard Modification
With a panel filter (AFE in this example) and snow grate removal, there was 5% better flow:
Mk7 GTI panel filter and snow guard modification
Turbo Inlet Pipe (TIP) shows some distinct gains over stock (note APR intake did not provide significant flow increase compared to the panel filter and snow grate removal):
TIP comparison - APR vs panel
APR intake and APR inlet pipe
Turbo Inlet pipe shoot out, Burger Motor Sport and MST with elbow take the lead:
Inlet pipe testing
The elbow gives a boost also....
All these also increase intake noise alot.. DV+ also gives nice turbo noises when coming off the throttle.
If you really want a loud intake, disconnect the airbox and just have the turbo inletpipe, did this to see how it sounded when installing my intake parts...
Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
