Page 33 of 84 FirstFirst ... 2331323334354383 ... LastLast
Results 321 to 330 of 833
Thread: Tigger73's 162TSI Sportline
  1. #321
    Quote Originally Posted by GreyGoose_X View Post
    Would love to see a step by step write up of how you eventually install the mk7 R exhaust on your Tiguan! That’s def a project on the cards for me too.
    I’ll just be taking the stock Mk7 exhaust to an exhaust shop and getting them to modify it to fit.
    I’ll look to get some photos and a description of what changes had to be made to get it to fit.
    Ran some timed 0-100’s this morning.
    Was quite surprised with the results:
    So that’s 0.4sec off the stock 0-100 time just from an intake!
    Morning, that’s a massive performance increase with just an intake upgrade!
    We’re all the conditions and settings the same as your original run without the intake?
  4. #324
    Dec 2018
    AU
    Had you verified stock times are 6.5 with that same gps device beforehand though? If so, good result without a tune
  5. #325
    Dec 2017
    Castle Hill, NSW
    Wow, makes me want to go out and hack away the snow guard right now! Not much snow here in Sydney.
  6. #326
    Quote Originally Posted by Melbourne_Tiggy View Post
    Were all the conditions and settings the same as your original run without the intake?
    I can’t remember exactly what temps the stock run was done at but it certainly wasn’t a hot day. This morning was about 22 deg C so would have been max 10 deg C between the 2 - probably less.
    Quote Originally Posted by Psych101 View Post
    Yes. Stock run was using same device and ran both directions on same road to check/verify.
    I was surprised at the difference. Most times intake just makes noise and no measurable performance gains but this is massive. I was kind of expecting 0.1s max but 0.4s is a significant gain.
    I suspect the snow grate delete on the stock intake would give a little more at top end too.
    Plus intake upgrade keeps warranty intact Tigger73's 162TSI Sportline
    Dec 2017
    Castle Hill, NSW
    And for those who just want to remove the snow grate, I just did it. Took less than 5 minutes, lifted straight out, and didn't even get my hands dirty. I have no way of knowing if that made any difference, but I figured it couldn't hurt
  8. #328
    Quote Originally Posted by OZROD View Post
    From my testing I think you may get a modest increase. If you also installed a high flow panel filter you’d probably be able to get a measurable difference.
    I think the filter element plays a decent part as well as the more direct flow path with the Racingline intake.
    Confirming a moderate increase. Snow grate removal was tested and there was a 3% increase in CFM:
    Mk7 GTI Stock Airbox Snow Guard Modification
    With a panel filter (AFE in this example) and snow grate removal, there was 5% better flow:
    Mk7 GTI panel filter and snow guard modification
    Turbo Inlet Pipe (TIP) shows some distinct gains over stock (note APR intake did not provide significant flow increase compared to the panel filter and snow grate removal):
    TIP comparison - APR vs panel
    APR intake and APR inlet pipe
    Turbo Inlet pipe shoot out, Burger Motor Sport and MST with elbow take the lead:
    Inlet pipe testing
    The elbow gives a boost also....
  10. #330
    Sep 2011
    Melbourne, Victoria
    Inlet pipe testing
    All these also increase intake noise alot.. DV+ also gives nice turbo noises when coming off the throttle.
    If you really want a loud intake, disconnect the airbox and just have the turbo inletpipe, did this to see how it sounded when installing my intake parts...
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
