Page 29 of 84 FirstFirst ... 1927282930313979 ... LastLast
Results 281 to 290 of 833
Thread: Tigger73's 162TSI Sportline
  1. #281
    Dec 2018
    AU
    The kit comes with a cleaning solution which is designed to take off dirt/oils/coatings. You do need to make sure the plastic is clean before applying the coating.
    And yes if it last 6-12 months and then I have to re-coat I'm not going to be too fussed. There's still plenty left in the bottle.
    Did you mask painted areas off and does it come off easily if you make a mistake?
  2. #282
    Quote Originally Posted by Psych101 View Post
    No need to mask off. Comes off with a damp cloth - just keep one handy and fix up any small mistakes as you go.
    I put down a drop sheet just to catch any drips so I didn't stain up the drive.
    Sep 2011
    Melbourne, Victoria
    I got ny chrome parts wrapped in gloss black..
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
  4. #284
    Quote Originally Posted by INASNT View Post
    I looked into wrapping and painting too.
    Problem with wrap on the textured plastic is that the wrap doesn't stick all that well to the surface. So you really need to fill it first before wrapping.
    Same goes with painting you really need to fill it first to create a smooth surface before applying paint.
    To fill you really need to take the trims off the car to fill/sand/paint. So it just started getting more difficult and expensive.
    Sep 2011
    Melbourne, Victoria
    The only parts you cant wrap are the plastic wheel arches, rest no issues
  6. #286
    Yeah though the car wrap guy I spoke with said you're still going to get an orange peel effect on plastic trims that aren't filled so you're back to needing to fill before wrapping. Just if you're going to spend a decent amount of time and $ on wrapping all the lower body panels to end up with a less than perfect job. You'll end up pulling it all off and doing it properly.
    Or in my case just spend $30 to make it 80% better and be happy. In terms of bang for buck I think either plasti-dip or the plastic restorer are not bad options. I'll have to see how the restorer wears over time.
    Took a few shots over the last couple of days:
    Tigger73's 162TSI Sportline-img_0460-jpg
    Tigger73's 162TSI Sportline-img_0464-jpg
    Tigger73's 162TSI Sportline-img_3922a-jpg
    Tigger73's 162TSI Sportline-img_3926-jpg
    Tigger73's 162TSI Sportline-img_3933a-jpg
    And a few more:
    Tigger73's 162TSI Sportline-img_3901a-jpg
    Tigger73's 162TSI Sportline-img_3936-jpg
    Tigger73's 162TSI Sportline-img_3942-jpg
    Tigger73's 162TSI Sportline-img_3946a-jpg
    Tigger73's 162TSI Sportline-img_3956-jpg
    And a few more:
    As discussed offline, a great spread.
    This is going to be one sweet Tig once the wheels are locked in and perhaps some fat ovals out the back spewing real emissions.
    Non R-Line front bar FTW.
  10. #290
    Well just pulled the trigger on a TTE475 earlier today...
    Tigger73's 162TSI Sportline-372935_1-jpg
    Tigger73's 162TSI Sportline-372935_2-jpg
    Tigger73's 162TSI Sportline-372935_3-jpg
    Tigger73's 162TSI Sportline-372935_4-jpg
    Tigger73's 162TSI Sportline-tte475-20tsi-turbocharger-jpg
    Here's the link: VAG 2.0 TSI MQB TTE475 UPGRADE TURBOCHARGER | TTE Global | Performance Motorsport Parts
