Originally Posted by
tigger73
Although I agree with what you're saying, there's not really too many other options that are 1) affordable 2) give reasonable results.
The dyno I use is one of the highest use Mainline dynos in the country. I'm well aware that there's a number of factors that can have a big influence on the result (tyre pressures, ambient temps, heat soak in warming up, strapping tension, ramp rate, etc, etc). I'm well aware it's not perfect, however if you get a good operator you can achieve some reasonably repeatable results.
I'll also be doing some time 0-100 runs in the not too distant future and the combination of the 2 will give a reasonable indication of the performance of the car. Who knows I may even put it down the 1/4 mile, however I'm not really chasing numbers. It's a daily driver and it has to do that job well (my mods are geared around making it the most enjoyable daily driver) and the other stuff is really a bonus.
