Page 10 of 84 FirstFirst ... 891011122060 ... LastLast
Results 91 to 100 of 833
Thread: Tigger73's 162TSI Sportline
  1. #91
    Quote Originally Posted by Melbourne_Tiggy View Post
    Well done! Now you have a baseline before you install your hybrid IS38 and get a custom tune.
    Yes still have to decide which route to head in terms of hardware and tuning.
    Tigger am I reading that correctly......461nm atw?????
    That’s 461Nm at the roller. This is uncorrected torque measured by the dyno. Some people will then try and calculate a torque figure but it’s pretty difficult as it will depend on tyre size and a bunch of other driveline parameters.
    Aug 2015
    That doesn't make any sense, if the calculation for torque isn't accurate or can't be taken as true at the wheel figure, then neither can the kW figure as the two are directly linked, kW is a function of Torque.
    So either they're both accurate or neither is.
    WEN Technology - Calculators
    Power-Torque - WEN Technology
    Sent from my iPhone using Tapatalk Pro
  4. #94
    Quote Originally Posted by rscott4563 View Post
    Power figures are kwaw which are a calculated value.
    Torque figures on the dyno sheet are the actual/measured torque on the dyno roller.
    I'm not sure of the actual calculation/conversion that is used for the kwaw power figures, but the dyno guys do it all day every day so I'll take their word for it.
    There's always discussion about torque. Some dyno operators will print out torque curves and give you a calculated engine torque (so you can try and compare it to manufacturer figures), however there's a lot of errors/assumptions when you do this (like exactly how squashed were the tyres on the roller and how worn are your tyres) so it's really hard to calculate the engine torque accurately which is why this dyno operator just gives the measured dyno torque value (which is true/correct).
    Aug 2015
    Refer to my previous link, physics don't lie.
    kW (or HP) and Nm (or lbft) are directly linked, power is a result of rpm and torque.
    Not saying there is anything wrong with the figures you have on your dyno report. Just saying that if you are saying that the torque figure is not accurate then unfortunately neither is your power figure. But also vice versa. Tigger73's 162TSI Sportline
  6. #96
    Understand what you're saying. I'm not too fussed about the torque figure to be honest. You change your tyres (or what gear you're running in) and you'll end up with a different figure.
    I'm not trying to relate it back to manufacturer figures (which some people try to) so I'm not really worried.
    What is most important is that I run back on the same dyno with simliar conditions and I can then compare stock vs stage 1 vs stage 2
    Aug 2015
    Just remember that this "different figure" will be both the torque and kW figures.
    Agreed, that's the key. Actual figures reported on a dyno (especially peak figures) are pretty pointless due to the shear number of variables between dyno types, testing methods, external factors, etc. It's all about the delta and keeping all testing conditions as identical as possible.
  8. #98
    Dec 2010
    Helensburgh
    You can forget even doing reliable back to back comparisons unless they are done on the same day on a chassis dyno, too many variables and even the operator can influence what the outcome is. Chassis dynos are good for doing stuff like mapping or fault finding which they do well but getting reliable & repeatable figures out of one is like drawing numbers out of a hat. It takes a lot of dedicated training to get good numbers out of an engine dyno and that has a lot less influence from outside factors.
  9. #99
    Quote Originally Posted by Ozsko View Post
    Although I agree with what you're saying, there's not really too many other options that are 1) affordable 2) give reasonable results.
    The dyno I use is one of the highest use Mainline dynos in the country. I'm well aware that there's a number of factors that can have a big influence on the result (tyre pressures, ambient temps, heat soak in warming up, strapping tension, ramp rate, etc, etc). I'm well aware it's not perfect, however if you get a good operator you can achieve some reasonably repeatable results.
    I'll also be doing some time 0-100 runs in the not too distant future and the combination of the 2 will give a reasonable indication of the performance of the car. Who knows I may even put it down the 1/4 mile, however I'm not really chasing numbers. It's a daily driver and it has to do that job well (my mods are geared around making it the most enjoyable daily driver) and the other stuff is really a bonus.
    Hi Tigger, I highly recommend using a Draggy device for measuring your performance stats. As part of its data capture it validates the angle of the terrain (%incline/decline) and if it’s within a certain threshold you can post it and compare your performance to cars in Au and around the world. In terms of accuracy, it has been demonstrated to be similar to Vbox. A great little device for under $200.
    All the best with your performance journey. I’m looking forward to reading about your selections and stats!
