That looks like exactly the right product for the job!
Will have to hunt down a local supplier. Looks like Mothers do a product available at Supercheap but this doesn’t contain dyes to colour the plastic. Otherwise the product you linked is on eBay...
Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
I'm more interested in how it sits in the cavity, i.e. without the false floor![]()
Ahhh. Well looks just like a spare wheel in the wheel well. Not much different to the space saver apart from being a bit taller. I’ll get some pics later today and post them up for you.
Ok took some shots of the tyre well with full size 17” Tulsa wheel installed.
One of the limiting factors of fitting the floor with full-size wheel is the handle on the floor which protrudes into the subfloor area:
So I decided to try removing the back off the handle to get a little more clearance:
Only busted one clip
In case anyone is trying this here’s what the clips look like:
Boot floor sits marginally lower now:
Thanks for that!
Looks like if I did the same with a narrower tyre it might just work out and there's enough space for the sub too.
I need the floor flat and in place as the wife uses the car to deliver cakes she makes on the weekend too.
The tyre on the 17x7 Tulsa is a 215/65R17 so is already pretty narrow. This is the reason I didn't go with a "matching" 20" Kapstadt or even a stock 18' rim as they both run a 235 width tyre and would push the boot floor higher. With the modified handle it almost sits flush on top of the spare wheel.
I think if you pulled the handle completely off you'd get the boot floor sitting on the spare wheel and not have a "high spot" at all. Though now with the back of the handle off it's barely noticeable.
As it sits, it’s a pretty good compromise. I’ll probably do same and just carry it for road trips... around town (99% of my trips) a space saver will do.
It’s a shame VW didn’t leave enough room for a Suzuka option even if they only supplied a space saver. That’s a missed opportunity for dealers to up-sell to a 5 wheel set.
Tiguan Highline 162TSI | Indium Grey | DAP | MY18
