All I’ll say is that if you want to tune it then you want to get the 162TSI.
There’s nothing out there for the 132TSI as it’s not like the first gen Tig where the 132 was just a detuned version of the 162.
This time around the 132TSI is a completely different motor with high compression ratio for greater efficiency. There’s no tuners that have touched these yet (a number of tunes already for the 162). And likelihood there won’t be any/many that will as the market for tuned 132TSI this will likely not be that big.
The 162 will piggyback off all the developments for the Mk7 GTI so you’ll see things like intakes and other hardware bits you’ll be able to use but the 132 is starting from scratch so my bet is most of this won’t get off the ground unless you’re prepared to go full custom build/tune.
