Thanks for the detailed reply.
That's what you have is the top of the range as on all Highline or R-line and is called High model Full LED headlight with built in 2x motors for auto levelling and auto cornering and are DLA capable .On your is obviously already factory activated as my18.5 . On Tiguan Full LED headlight High beam use multiply segment LED( led module pcb has segment of 5x individually led-s diodes ) so it is able to dynamically individually switch on or off each LED or to fade in or fade out and plus all working in synchronic mode with 2x motors in combination controlled over AFS . Audi Matrix Full LED headlight use same things but without motors or moving parts but LED pcb use even more advanced LED PCB module with many more this small led diode in segments in low and high beam led units, also some model even use in cornering led modules in multiply segment pcb .
But still many people whih was able to compare including me claim that Tiguan has best and strongest Full LED headlight in market currently, even compared to most expensive Full LED Matrix like built in Audi q5 /q7 . Advantage of Audi matrix is no moving parts, smaller units less weight ,cheaper to produce and easy to make , less chance to failure . Unfortunately even this one in in Tiguan are more capable I think they will soon be discontinued as offcourse cost save to manufacture. But anyway feature is Matrix LED with no moving parts and I am sure is much better technology and will be far more advanced and is just beginning .I hope my next car wit LED headlight will have option in menu to user custom setup Kelvin Colour of Headlight LED light, from Cool Blue Daytime to Warm say 3000k -10000k to pick . Today almost all LED Headlights use artificially white cool LED which is to much bluish and is dangerous and can make problem to Driver and also blinds and annoy upcoming traffic , little bit warm more natural light close to halogen will resolve this.
Check this document where it shows both headlight assemblies and we did not get the DLA capable lights in the first 18 months??? Page 20 & 21 at this link Tiguan Owners manual - Google Drive
The file is on the second last line 3rd from the right. LED are full LED, if they aren't what are they? The basic LED headlight cannot have DLA activated (been there and proven that) but they can have HBA activated. The linked doc also goes on to explain in some detail the construction of the lights and what they do.
BTW the basic LED has far less high beam power as can be seen in the linked document.
I have first generation full led which came factory without DLA but has been upgraded and activated to DLA and this is all done from scratch from halogen to oem ,so this information from first hand and more accurate than your pdf![]()
Yes, a machine. He taught me how to do it myself. I'm happy since. I was worried maybe the adjustment is now too high, but in the months of driving only one car flashed me so I'm thinking they are fine.
I did ask the dealer to adjust slightly above the machines specs.
