When driving home the other day I noticed that the lights on my Highline didn't seem to be illuminating the road far enough ahead of me.
Any ideas how I can check the setting for this or anyone confirm if there highline has a way to adjust the vertical light level?
VW Tiguan 2018 162TSI Highline
VW Polo 2015 81TSI Comfortline
Ok, that might explain it. So the dealer would have to program an adjustment?
I had mine adjusted at the dealer, I found the lighting too low, making it difficult to drive especially across mountain roads.
You can adjust it using an allen key on the back of the headlight.
Current:
2017 Mk2 Tiguan 162TSI, R-line, White
2020 Mk7.5 Golf R Wagon, White
How does one adjust the self leveling headlights with an Allen key?
Is it the low beam or high beam that is too low?
Low beam
Have it checked by the dealer before fiddling with the height as there are many things that might lead to them being low. If the high beam is OK I would say the low beam is correct also. You also need to know how to layout the proper height lines on a wall and the distance the car is from that wall.
