Results 1 to 10 of 18
Thread: Tailgate Kessy Issues
    Feb 2015
    WV, USA
    Often, when I walk up to my locked vehicle, I cannot open the tailgate using the the button above the license plate. The kick to open never works. I have to use the fob to open the tailgate.
    I've had it to the dealer, but it seemed to work then!
    Can someone tell me where the kessy sensor for the tailgate is located? I had a trailer hitch installed and am wondering if it blocked the sensor and needs to be relocated.
    Nov 2016
    I think then sensor is in line with the RHS tail light cluster. Mine doesn’t seem to work 100% either especially if the surface isn’t smooth.
    Remember you need to have the key with you for it to work.
    One thing I have noticed is that if I have my key in my pocket while washing the car the hose sets it off and that always works!
    Sent from my iPhone using Tapatalk Pro
    Aug 2018
    Quote Originally Posted by wiredless View Post
    This, a prerequisite
    this happens to me all the time
    2018 Allspace 162TSI R Line
    Aug 2018
    Quote Originally Posted by pbrowne View Post
    Make sure you have this enabled in the vehicle setting - I think it’s in the doors and opening section and is called “easy open”
    Swiping with your foot should work between both sets of sensors. Between the 2 on the right and 2 on the left. Make sure 2nd set of keys not left inthe car.
    Sent from my SM-G928I using Tapatalk
    Dec 2010
    Helensburgh
    And make sure after sweeping your foot you step back a couple of paces.
    Dec 2010
    I found that kicking under the rear sensor (either), straight under the car works 100% of the time. Swiping or sweeping my foot works 50% of the time. As all of them need to have the key in your pocket And I can’t get it to work if the drivers door is open.
    Tiguan 162TSI Highline Indium | R-Line pack | DAP | Tow pack |
    Octavia 2012 vRS | TDI | White | DSG | Tow pack |
    Aug 2018
    Quote Originally Posted by Beowulf View Post
    How do you go with the tow bar, does it get in the way?
    I find I have to come in off centre on one side of the tow bar, and occasionally knock my shin on it....
    Interesting...
    I find if the drivers door is open when I start the ignition, I can't switch driver profiles when the active dash fires up.
    I have to switch through the menus in the central AV display
    This happen to any one else?
    Dec 2010
    Quote Originally Posted by iDiesel View Post
    The sensor is 20cm on the left or right of the tow bar so not even close to kicking the tow bar.
    Nov 2016
    Agree I have a Towbar and it doesn’t get in the way.
