Probably the same issue like in EU. Dealer should remove stering wheel and fix cables position around.
I don't know if there is a better place to post this, but here I go. I've had an odd noise from the steering, only when I turn the wheel. It is mechanical and sounds a bit like a ratchet except with a little more resonance. It is not loud. I did not notice for a while as I had music playing. I took it into the dealer for a look and they replaced the slip ring assembly (under warranty). it still makes the noise. Has anyone else noticed a noise from the steering? I really don't want to take the car back. The loaner Golf was nice enough but it's not the same!
My Tig has done about 3,000km and loving it, a few days ago I was reversing up my driveway and had fUll RH steering lock under acceleration and had a similar ratchet noise momentarily! Has been a once off and no action taken to date will monitor if it reoccurs.
Also did a trip up the Hume (mostly under cruise control) and having entered a town, cruise off, turning right in the middle of two round abouts got a strange single knock from the left hand front, once again has repeated itself since.
MY18Tiguan 162STI, Rline, DAP, T/B, Tungsten
Thanks for your responses. I'll monitor it and if I get more info I'll post it.
