Results 11 to 20 of 21
Thread: Steering Nervous/Twitchy.
    May 2019
    Yarra Valley, Vic
    After a few more days driving, I think I have a different perspective on the issue that is peeving me - thanks to some of your thoughts above. I think the suspension on the car, tends to have a considerable left to right to left rocking motion when you go over undulations (even small ones) in the road. Different DCC settings don't seem to make any difference, but just mask the effect.. So when travelling at speed, and you hit multiple undulations, you feel this through the steering. Does this sound familiar to any of you?
    2019 MY19.5 Highline (R-Line, S&V, Sunroof)
    Stage 3 - Etuners Motorsport - 228wkW, TCU Tune
    G Revision IHI IS38, BMS Panel Filter, CTS Turbo Elbow, CTS Downpipe, Dogbone Insert
    Dynamic Light Assist (OBD11), Eibach Pro Kit Suspension
    Pacific Paradise QLD
    Quote Originally Posted by davman View Post
    No more than any of my other VW's
    May 2019
    Yarra Valley, Vic
    Mmm, I have had heaps of VW's, none have had this problem. Only car that had this similar problem before was my Lifted 200 Series Cruiser, which had Caster adjustment issues.
    Aug 2018
    not me either.
    What does your tyre placard say?
    2 people = 38PSI
    Fully loaded = 39 front / 45 rear
    2018 Allspace 162TSI R Line
    May 2019
    Yarra Valley, Vic
    Yep that's pretty much it when you do the conversion to PSI
    Adelaide hills, SA
    After a few more days driving, I think I have a different perspective on the issue that is peeving me - thanks. Different DCC settings don't seem to make any difference, but just mask the effect..
    I’m not following....
    I’ve driven many Tiguans s2 and didn’t notice anything you have described. At what speeds are you driving over the undulations?
    May 2019
    Yarra Valley, Vic
    Hi All.
    I took my car back to the dealer who did a full wheel alignment and found that the Right Toe was -1.1 which was out of spec, so they have now adjusted it to +.7. Now I am not sure if it is a Placebo affect or not, but I do think it has mitigated some of the twitching issues - however time will tell. I think most of the my concerns now revolve around the body roll issues, which get exacerbated by the 20" Rims running at 40Psi not providing any assistance in absorbing the crap road conditions. I drove another brand new dealer car which had the same characteristics as mine, so at least the issue in not my car specific.
    Perhaps its time for an Eibach Pro Kit.
    Erskineville, NSW
    Do you really think higher spring rate and a lower ride height with less suspension travel will help?
    Sep 2011
    Melbourne, Victoria
    I found the stock suspension very floaty on anything else but sport, same with the steering wheel. Once you do any mods the front end will lift to the sky on hard acceleration.
    Now with the H&R springs i mainly drive in custom with wheel in sport and suspension in normal, rides nice and flat
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
    May 2019
    Yarra Valley, Vic
    Which H&R springs did you put in? Just the Sport Spring?
