Originally Posted by
Sydneykid
Aside from GPS speed nothing will compensate for tyre wear affecting the distance travelled with each wheel rotation (ie; speedos and ODB outputs are simple rpm counters). Even brand new, tyre sizes vary as well, so not all the same marked tyre sizes are in fact the same size (eg; diameter).
Gary
RPM doesnt come into it You could do a Km in 2nd gear and its just as far as doing it in 5th .But I think I know what you mean
Its impulses per kilometer in most electronically controlled cars today and mine is taken off one rear ABS sensor to tell ECU the number of clicks against a preset norm. To change it you have to change tyres or reset the ECU to accept a different reading per Km.
The difference between a new tyres reading and one that is nearly worn out is approx2.2 % of diameter so wont hardly upset the speedo, if anything will read slightly higher
ABS sensors also do this
Indirect TPMS use the ABS wheel speed sensors to detect wheels that are revolving at different speeds. An underinflated tyre will have a slightly smaller rolling radius and it's that that the car detects.
