Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Silicone inlet hose trouble
    Jan 2018
    Hey guys,
    Has anyone had any difficulties with a silicone turbo inlet hose fitting the stock box and stock turbo elbow? I've tried two different brands now that say they fit but they do not match up at all.
    Here is a photo of the issue.
    Any ideas, or brands that you guys have tried that has slotted in.
    Aug 2016
    Auckland, NZ
    I had no problems fitting an ECS Tuning one to mine when I had it but theirs looks a bit different to the one you have, yours looks to have sharper bends:
    Are you sure it isn’t something as simple as flipping it around the other way?
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
    I’ve got a Racingline one for sale at the moment. Ended up going back to stock as I didn’t like the fitment on the Tiguan.
    If you know what you’re looking at you can see that there’s a gap to where it should sit on the turbo inlet pipe. The hose doesn’t sit hard up against the shoulder and then there’s not so much to clamp to:
    I did think about cutting the hose but the ends to make it fit better but wasn’t an ideal result so took it off and will look at other options.
    Jan 2018
    Quote Originally Posted by NZ_GolfR View Post
    It only goes one way, I've tried flipping it and rotating it, but it only goes on one way, one hole is larger than the other hole.
    Jan 2018
    It's almost as if my turbo/inlet need to be rotated towards the firewall slightly.
    Oct 2015
    Are the two brands you’ve tried, both top of their price bracket- or the opposite end?
    And for guesses- is there a difference between the 132 engine and the 162 (I feel they are both different series/models of hardware)
    The 132 and 162 air intakes hoses are completely different. The 132TSI runs a MAF, whereas the 162 is MAFless.
    I’ve come to the conclusion that there’s a difference between the Tiguan and sedan/hatch layouts and that you really need the hoses/connectors to suit.
    I know with the Wagner intercooler I installed it had a different version for Golf and Tiguan. I believe this was mainly due to slightly different length intercooler inlet/outlet pipes.
    Jan 2018
    I've ordered an ECS Tuning hose now. If it's fit a car in here already surely I'll have some luck with it
    Quote Originally Posted by Hotlad View Post
    Third time lucky!
