Here’s a suggestion.
I’ve been using roof boxes for years with the A6 Allroad and agree, the biggest pain is what to do with the bloody things when you don’t need em.
Here’s what I did.
Bought two bike lifts, not sure what they’re called, but they’re designed to lift a push bike off the ground and store it. They came from ALDI so cheap as.
Made up a timber frame and attached it to the roof of the car port with a couple of brackets.
Screwed the bike lifts to the frame.
Back the car under.
Disconnect the roof racks from the car.
Lift the whole lot, roof box with racks attached, to the roof.
Easy peasy.
I’ve added a couple of occy straps underneath just in case the ropes let go and drop the whole lot on the car.
When it comes to putting the box back on I just lower it down to just above roof level, back the car underneath, lower it the last little bit and attach to the car. A one man operation.
Just be careful you don’t leave the car under while you’re doing the bulk of the lifting/lowering as the possibility exists that you could drop it on the car.
