Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Rline Ceramic Coating
    Apr 2018
    Quote Originally Posted by Kachingg View Post
    Yeah you are correct to get the best out of a coating a claybar yearly is a must like anything else if its not maintained it will degrade
    This maybe a dumb question
    - what is the best claybar to buy ?
    - when do you use it ?
    - how often should you use it ?
    Apr 2013
    Have a bit of a cruise on YouTube and detailing forums. Here’s a start:
    How To: Use Detailing Clay
    Clay Bar Tips & Facts
    GolfGTIforum.co.uk - An independent forum for Volkswagen Golf GTI enthusiasts.
    Once you’re done, something here should work:
    Car Care Products /
    All Brands /
    Exterior /
    Clay Bars & Decon
    It’s important to get the technique right. Light pressure only and renewing the exposed clay surface regularly. Yearly is probably enough but I’m sure some would do it more. I intended to do it yearly when I got the car but to be honest the older the car gets the less diligent I’ve become.
    Apr 2017
    belgrave victoria
    Yes it definitely possible to get your car coated make sure its a ceramic coat tho
    You will need a paint correction done this will be in addition to the coating cost
    Well worth doing imo my car always looks freshly waxed after just a hose off with the pressure wash
    I only handwash bi monthly to remove grime around the wheels and nooks and crannies that you can't get the washer into
    Plus it helps with fading that was a big part of my choice to coat as mine is red and fading is always a issue with that colour
