Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 91 to 100 of 115
Thread: Ride/Handling mods
  1. #91
    Jan 2019
    Quote Originally Posted by LaNOS View Post
    Hey guys in relation to ride handling, I'm having front and rear sway bars put in next February at Eurotune. I know most people only do the rear sway bar but if I did both what would the effects be?
    Sent from my SM-G973F using Tapatalk
    You will most likely end up with understeer with the front sway bar. I've done the rear, and honestly, the car handles perfectly in bends now. My mechanic with an RSQ3 who also has an aftermarket rear swaybar prefers the handling of my Tig over his.
    I would discuss the possible effects of having both sway bars fitted with Eurotune.
    Sent from my Pixel 3 using Tapatalk
  2. #92
    Feb 2014
    The guy at Eurotune seemed to say that the effects of the swaybar has more to do with weight distribution of the car rather simply to do with the front wheel or rear wheel bias alone.
    I did ask if the front swaybar would counter the effects of the rear however he said it wouldnt and instead would further reduce body roll.
  3. #93
    Quote Originally Posted by Mozzz View Post
    Was $403 AUD yesterday ... I may have purchased a set
    404 TODAY purchased
  4. #94
    Erskineville, NSW
    I would agree with your mechanic.
    IMO, the reason most don't fit the front is because it is expensive to fit. The rear is a 30 minute job. The front is 1.5-2 hours (subframe drop) plus a wheel alignment.
    There have been plenty of Golfs fit F&R. The effect is quite similar.
  5. #95
    Agree that most of the improvement is in the rear sway bar anyway as the stock front sway bar is already a decent size (26mm from memory). As long as you don't go ridiculously big on the rear you should tighten things up without causing the car to oversteer.
    The front is in the law of diminishing returns. It costs a lot more (including installation) for a modest improvement in handling. I did it on my gen1 Tig and bang for buck the rear bar upgrade was money well spent and the front was just when you ran out of things to modify and wanted to throw cash at the car. Of course if you were chasing track times then it's probably worth it but for daily driving duties the rear bar is all you really need.
    Nov 2018
    Thanks for the informed experience information tigger73 - thanks to the great feedback on this forum I am going to do the rear sway bar, eibach springs and some ceramic front disc pads in January 2021 on my 2018 Wolfie and will report back ...
  7. #97
    Erskineville, NSW
    Agree that most of the improvement is in the rear sway bar anyway as the stock front sway bar is already a decent size (26mm from memory). .
    Bar diameter isn't a great measure of what the bar does. A lot of OEM bars are hollow and haven't been heat treated. They don't have the same torsional strength as an equal diameter, solid aftermarket bar that has been heat treated.
  8. #98
    Feb 2014
    Ride/Handling mods-20201231_123755-jpgI got this quote from Eurotune, the rear sway bar has also been added onto this for a total of $5500. I was one of the people that rushed to get the APR Stage II tune done and then rolled back to Stage I till I could sort out enough time for the hardware to be installed. I believe both the Front/Rear sway bars to be either racingline or HardingPerformance ones. Thoughts?
    Thanks so much for all the information so far as well, its been very informative!
  9. #99
    Only thing missing is an IS38
    Feb 2014
    Haha I am curious about that, it could be good but will that ruin the longevity of the engine? I was going to go to Stage 2.5 and just do the intercooler.
