2018 VW Tiguan 162 TSI Sportline
APR Stage 3 ECU tune, TVS Stage 2+ TCU tune, IS38 Rev F turbo, APR intercooler, APR dump pipe, Racingline intake kit & 034 rear swaybar.
XForce Varex muffler & controller on the way.
If you want more turn in try toeing out the front wheels 1 mm per side (commonly they are toed in 2+ mm per side) and the rear 2 mm tow out each side (commonly they are 3+ mm toed in). That's an inexpensive and quick wheel alignment adjustment using the standard adjusters. Not as low a cost, but best mod for turn in is more caster, check around for a kit around that increases that gives more positive caster, plus there will be fitting costs if you can't DIY.
Gary
Stiffest setting
I just hate cam based adjusters with a passion you would not believe. It comes from my karting days where they are standard on most karts and I designed a new adjuster that is now sold world wide or used to be because we have not been in karting for some years and I haven't kept up to date.
