Results 1 to 10 of 14
Thread: Reverse tail lights
    May 2017
    Reverse tail lights
    Just purchased a new 132tsi comfortline. I noticed that when I put it in reverse there is only one reverse light illuminated. Not sure if the other bulb is busted or whether there is simply 1 reverse light. I had read on a European forum that this is the case but wanted to double check.
    Standard on many European cars. The other light (which is basically useless in Aust) is a fog light.
    Dec 2008
    Sydney/Canberra
    There will be only one reverse light.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    Can you use a VCDS to program the rear fog light to come on when you engage reverse gear?
    Sent from my SM-G930F using Tapatalk
    Ordered: 2017 build date Tiguan 162 TSI Highline with DAP in Tungsten Silver and rear luggage tray. ETA: late April / Early May. I did not have to wait. I took delivery on 11 March 2017.
    Quote Originally Posted by Delewin View Post
    I don't think so but feel free to try. I ended up buying another genuine taillight for the US market from o'seas with a second reverse light and hooking it up in my Golf.
    Delewin: My apology to Lucus_R, but yes- it's indeed possible to make the rear fog light operate as a reverse light.
    There's many ways to do this with Leuchte programming, but perhaps the easiest is as follows:
    1. Select 09 - Central Electr control module
    2. Select Security Access - 16 from the "Open Controller" screen
    3. Enter the magic number 31347 and return to the "Open Controller" screen
    4. Select Adaptation - 10 from the the "Open Controller" screen
    5. Enter LA72 into the search box and from the pull-down arrow, select ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26
    6. The default value of this channel should be not active - only if this is so, change the setting to Rückfahrlicht
    7. Click the Doit! button to accept the change
    This process automatically applies the same illumination level to the reverse light that is factory set for the fog light function (which will be 127 since the new Tiggy has LED tails)
    PS: I don't own the new Tiggy (I have a Golf mk7), but I have found that it's also useful to turn-on the 3rd Brake light when reversing. It's unfortunately a red color, but the higher position of the LED strip seems to provide a good general illumination when going backwards!
    If you also want to apply this function to the 3rd Brake light - see my instruction HERE. Note: use the instructions for the last column of the table, but don't apply the changes in column 1, or 2 to the Tiggy (the 3rd Brake light on the Golf mk7 is factory programmed differently to your beast)
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    Many thanks DV52. I'm still snowed over with work so my to do list is growing.
    Nov 2016
    There are 2 functioning reverse lights on the 162Tsi
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    Yes. I can confirm there are 2 functioning reverse lights on my 162 TSI.
    Nov 2013
    AUS
    Hi Don, just wondering ... so the 3rd rear light is on a lower setting with the reversing lights on and then increases to the normal brightness when the brakes are activated?
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
