Standard on many European cars. The other light (which is basically useless in Aust) is a fog light.
Just purchased a new 132tsi comfortline. I noticed that when I put it in reverse there is only one reverse light illuminated. Not sure if the other bulb is busted or whether there is simply 1 reverse light. I had read on a European forum that this is the case but wanted to double check.
There will be only one reverse light.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Can you use a VCDS to program the rear fog light to come on when you engage reverse gear?
Sent from my SM-G930F using Tapatalk
Ordered: 2017 build date Tiguan 162 TSI Highline with DAP in Tungsten Silver and rear luggage tray. ETA: late April / Early May. I did not have to wait. I took delivery on 11 March 2017.
Delewin: My apology to Lucus_R, but yes- it's indeed possible to make the rear fog light operate as a reverse light.
There's many ways to do this with Leuchte programming, but perhaps the easiest is as follows:
- Select 09 - Central Electr control module
- Select Security Access - 16 from the "Open Controller" screen
- Enter the magic number 31347 and return to the "Open Controller" screen
- Select Adaptation - 10 from the the "Open Controller" screen
- Enter LA72 into the search box and from the pull-down arrow, select ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26
- The default value of this channel should be not active - only if this is so, change the setting to Rückfahrlicht
- Click the Doit! button to accept the change
This process automatically applies the same illumination level to the reverse light that is factory set for the fog light function (which will be 127 since the new Tiggy has LED tails)
PS: I don't own the new Tiggy (I have a Golf mk7), but I have found that it's also useful to turn-on the 3rd Brake light when reversing. It's unfortunately a red color, but the higher position of the LED strip seems to provide a good general illumination when going backwards!
If you also want to apply this function to the 3rd Brake light - see my instruction HERE. Note: use the instructions for the last column of the table, but don't apply the changes in column 1, or 2 to the Tiggy (the 3rd Brake light on the Golf mk7 is factory programmed differently to your beast)
Many thanks DV52. I'm still snowed over with work so my to do list is growing.
There are 2 functioning reverse lights on the 162Tsi
Yes. I can confirm there are 2 functioning reverse lights on my 162 TSI.
