Results 1 to 6 of 6
Thread: Reverse Camera (odbeleven)- need help
    Apr 2018
    Greece
    Hello,
    I recently bought from eBay my reverse camera.
    The problem is that i cant see the steering wheel guidelines... All i can see is the image from behind.
    I programmed the r. camera through the ODBeleven.
    please can you help me?
    Apr 2018
    Greece
    Reverse Camera (odbeleven)- need help-pic-1-jpg
    Reverse Camera (odbeleven)- need help-pic-2-jpg
    Reverse Camera (odbeleven)- need help-pic-3-jpg
    Aug 2017
    Uk
    There’s two different cameras, normal without lines, and high line with lines, guess you got the normal one
    the lines are to do with the camera and there’s no way to program them
    The only way to get the bending guidelines is to use the proper highline camera module that includes a controller that connects to the canbus. This receives the steering angle sensor data and uses that to generate the moving overlay.
    Something like this:
    New VW Tiguan 2016 - High Line Rear View Camera KIT With Guidance Lines
    Apr 2018
    Greece
    this is my r. camera... description says its highline
    Reverse Camera (odbeleven)- need help-screenshot_20180405-141910-jpgReverse Camera (odbeleven)- need help-screenshot_20180405-141853-jpg
    Can you see a camera at address 6c in obd11?
    You shouldn't normally have to change anything but check coding and adaptation.
    You may need to just add it to the gateway list of installed modules maybe...
