Hello,
I recently bought from eBay my reverse camera.
The problem is that i cant see the steering wheel guidelines... All i can see is the image from behind.
I programmed the r. camera through the ODBeleven.
please can you help me?
There’s two different cameras, normal without lines, and high line with lines, guess you got the normal one
the lines are to do with the camera and there’s no way to program them
The only way to get the bending guidelines is to use the proper highline camera module that includes a controller that connects to the canbus. This receives the steering angle sensor data and uses that to generate the moving overlay.
Something like this:
New VW Tiguan 2016 - High Line Rear View Camera KIT With Guidance Lines
Can you see a camera at address 6c in obd11?
You shouldn't normally have to change anything but check coding and adaptation.
You may need to just add it to the gateway list of installed modules maybe...
