I would stay away from the polyurethane bushes and inserts from my experience. You should at the very least do the "dogbone" mount insert and for this I would recommend one of the metal inserts. I have tried several poly bush inserts (and complete replacement mounts) and they all had an increase in NVH, wheras the metal inserts do not.
I am very sensitive to increased NVH in the car and experimented with various options when I had my MK6 Golf R. After some trial and error, the poly bushes were out and I settled on one of the metal inserts which did:
- Firmed up the engine/gearbox movement nicely
- Had very little change to NVH
- Can easily be removed if you decide you dont like it (this cannot be done with the poly bushes as they break when you try to remove them).
So when I moved on from the Golf R and moved to a Mk7 Golf GTI I went straight to a metal insert for the dogbone and never thought about it again.
034Motorsport Billet Aluminium MQB Dogbone Mount Insert Version 2 '-' VW Mk7, Audi 8V | AutoInstruct
