It is amazing to read how some people trying to make same car to be louder than more quite and on other side others as myself how to make it less noise and to reduce engine noise ,cabin noise ,tyre noise etc ...he he
Hi
Is that VW/ Audi hardware thing called ''soundaktor''. Recently when was under car I noticed on my Q3 when comparing to Tiguan Muffler exhaust pipe on q3 has extra some wiring and solenoids going inside Muffler I don't know exactly what Is purpose? maybe to control reduce open/close inside pipe size and control in sound change or pure performance related ? Is this thing maybe responsible why Audi q3 is so quit when engine is running on idle, sometime make me think is engine off and put smile on my face.I am wondering if yes if is than any way possible to retrofit tweak similar on Tiguan to make it really quite running as Q3 engine .
Thx Exxie for explanation , if this will make it quieter I would be always happy to make mod and retrofit on my Tiguan anything will make it quitter , however wondering if Highline or R-line Tiguan 2 have this hardware thing already built in? my 132 Comfortline don't, the second if possible to retrofit which module control this thing and where wiring is connected to?
One more question why my Tiguan every time when motor had rest and is cool down ( usually If not driven overnight ) when I start it I hear some very noise loud sound like some sort of high power high pressure pump and burning engine sound, it take like 20 sec. each time on cold than stop disconnect back to normal ? Thx
I wouldn't bother retrofitting an active valve system to make the exhaust quieter (they're generally on sports exhausts that are much louder, so they need a quiet mode). If you want to muffle your exhaust more, you could possibly add some material to your existing muffler. Speak to an exhaust shop.
Having said that, I doubt that the exhaust of a 132tsi makes much noise. It's more likely to be engine noise entering the cabin.
Might be the oil pump or something like that, probably nothing to worry about. If you're concerned, ask the dealership.
Just a small update for anyone interested.
Initially, the resonator delete was subtle, but as I've done more KMs, it's gotten progressively louder. There are indeed little farts on upshift, but only when shifting from high-ish revs and at least 50% throttle.
I'm hoping it continues to develop on this trajectory. I won't be touching the muffler. Downpipe and tune will come in time and this should bring a lot more noise as well. Would be good to hear from the initial OP (Shock) re the Unitronic flash.
Thx Exxie for explanation , will not than touch it than. You and Ozsko are right , motor noise and engine noise is coming from engine bay , I try to put some sound acoustic 1cm thick sheet used for roof insulation and it make bit difference, however this is only provisional for demo will need proper job
. Reason for Engine to be noise on 2.0L compared to 1.4 which is very very low noise same as Q3 , , is 2.0L use chain and 1.4 use timing belt which I much more prefer , easy to replace yourself less noise and vibration, don't see reason VW to use troublesome chain . New audi Q5( also upcoming 1.5 VW engine) use now timing belt according to video reviews and was noted that all new VW and AUDI engine will return back to timing belt on upcoming cars. Today quality timing belts can go over 200000km easy, but chain knowing VW Golf V GT can start problems as early wearing at 40k-60k km, hope Tiguan will not have this issue with early chain wear , whish they used timing belt instead ;(
