I sometimes still get the check engine light but it goes away after a day or so by itself...
Agree with Inasnt, if you want more sound but not over the top get a down pipe. It will also give you the benefit of quicker turbo spool and better power under the curve. You will need a stage 2 tune or someone to code out the CEL re cat efficiency / O2 running lean. But far more rewarding than just the resonator delete, which doesn’t give you a performance gain or much of a sound increase. The other option if you want more sound is to get a hi flowing panel filter and removing the snow grate in the air box. Otherwise you can change to an open air intake, and there will be plenty of intake swooshing sounds to enjoy!
Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
And if anyone is removing and replacing their OEM downpipe/cat I would like to buy it off you to 1. Make a jig and 2. Modify it with larger pipe work throughout post the O2 sensor, a drop in pressure should theoretically make more power.
Will do pre/post dyno read outs.
Have you considered the prefabricated exhaust systems already available? Bolt on and all bends are mandrel/highflow. Some of the systems we have looked at are pretty trick and you can add/delete mufflers and various Cats at your choice. Understand you wanting to have a custom system, our families business has specialised in hypo custom exhausts for over 40 years. After looking at the major components i.e dump pipe (or down pipe as they are now known) it would be hard to replicate or improve on the R and D that’s been done, both from a performance and $ perspective. If your going 3 inch straight through it’s definitely going to be loud, as Tigger mentioned elsewhere on the forum exhaust note is a personal taste, but droning at cruise speed creates a special type of headache lol. I learned that long ago. Look forward to seeing how it turns out 👍
No I didn't do the snowgrate mod or high flow filter as where I'm planning on going I'll need more flow than the stock airbox will allow. I think if you were going stage 1/2 then the modified stock airbox should be sufficient as it does flow quite well with these mods.
It's even been proven to flow better than some brand name aftermarket intakes.
The only reason to change it out would be to get some more induction noise.
I’ve removed the snow grate and re inserted the stock air cleaner. Not going to waste money on an aftermarket “high flow” filter as I’ve never seen a gain from this in past builds. No change to induction noise or engine sound, which was expected. There is no doubt the snow grate is an obstruction so it’s only a benefit to remove. I will leave it this way until I can get the pennies together for an airbox 👍
anyone in Sydney got recommendations for workshops that can do a res delete?
i'm getting quoted $150+ and im wondering if this is just "Sydney tax" compared to others here reporting $80-100 for a res delete...
I expect this a pretty simple/quick job?
MY09 MKV Golf R32 | Black Pearl | Recaros | Sunroof | RNS510 | Purchased Feb '10 | Sold Jul '17
MY19 MKII Tiguan Highline 162TSI | Indium Grey | S&V | Pano Roof | R-Line | Purchased Nov '18
Try Daniel at Impossible Fabrication in Moorebank, he does work on my car and the cars I've built/tune in the trak-life group.
Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
