Yep, go into your Nav settings, then in one of the sub menus you can and tick the specific POIs you'd like.
I have added red light cameras to my POI list but would like to only view them on my navigation map without petrol stations etc, is that possible?
MY18 Tiguan R Line Black-162 Highline TSI
Drivers Assistance Package - Sunroof - Tow Bar
Ordered July 17 Arrived December 17 Delivery Jan 18
Current:
2017 Mk2 Tiguan 162TSI, R-line, White
2020 Mk7.5 Golf R Wagon, White
Thanks for that, I was close but hadn't gone into the sub folder.
How did you add the cameras?
This is from a previous post, hope it helps.
Speed and Red lights Cameras POIs Australia - MIB ii
Hi guys,
I put together an up-to-date POI file with all the fixed, point to point and red lights cameras for the whole of Australia.
To install them follow the instructions below (credit to Primordial from vwgolf.net.au). Those are for MIBii, not sure if it works for MIBi.
1. Download the zip file from here:
Dropbox - Error
2: Extract the ZIP file to the root of the SD card
3: Insert the SDCard into the 2nd slot in the glovebox
3: Press the NAV button on your MIB II
4: Press Setup --> Manage Memory --> Update My POI's --> Update --> Select SD Card 2
Done! you can now remove the SD card and enjoy your newly updated POIs!
I
Reply Reply With Quote Blog this Post
The dropbox link didn't copy but if you search for the original post it will be there.
HinWazza
Which original post should we be searching?
Thanks
Easiest way google 'vw red light cameras POI dropbox' then click on the watercooled option.
Thanks Wazza will do when I get back home next week
Fred
Found this
Volkswagen/Skoda Speed/Redlight Camera POI 2016/17 - VW - Automotive
Thanks Wazza
VW Tiguan 2018 162TSI Highline
VW Polo 2015 81TSI Comfortline
