I might play around with VCDS on the weekend to see if I can see when the Haldex is engaging and disengaging the rear wheels.
It will be a world first (literally) if you get any acknowledgement of a problem.
Maybe I am wrong, but I have feeling that you will receive same response as me and the other owners with similar issue: sorry but nothing wrong with your car, is just 'characteristic of VW transmission drive''.
I noticed a bit of a sound similar to what you describe tigger73 - in a parking building yesterday after driving in the torrential rain we had on Friday in Sydney. I’d actually pulled a couple of very hard takeoffs at the lights (0-60kph) to test the Haldex (Which was amazing!) and wonder if it remained engaged for the remainder of a short trip.
I left the parking building 10min later and no sound.
This is the same parking building I frequent daily and never noticed it before. It was the first time driving properly hard in the wet and forcing the Haldex to work.
I noticed there is coding to set the Haldex parameters - it might be worth checking those and see if the default (quiet) is not set for some reason.
As another idea; I think the esp program grabs the brakes on the inside wheels when cornering to assist with stability and to turn tighter. Is that correct? Maybe that’s come into play at parking speeds?
Hi Spacemannz , just my advice don't even think in Haldex coding set from default normal to quite, you will lose so much rear power that car will fill so sluggish .
I test this when bought car and find those clunking noise , and find same Haldex coding option . Quiet option was looking very promising which i think should fix my car clunking noise to be ''quiet'' he he was so wrong.
So I set on that quiet mode and keep driving forgetting even that I changed . The clunking / rattle noise remained the same but my car was so sluggish! Playing with other coding experimenting didn't know that was the reason car is sluggish. At that time I was so disappointed in 132tsi engine performance especially going up to hill, But after week or 2 I remembered that I changed Haldex coding and I put back to normal and even gone after testing loud mode.
I notice big pull improvement going from standard but not any more noise than standard .So my preferred settings is the last one.
Well as you predicted the dealer couldn't find anything wrong with my car and said it behaving normally and couldn't fault it.
I did run some logs on the car over the weekend, however although I could see the Haldex engaging on take-off I think I'll have to run some more to log the steering angle sensor vs. axle speed delta. The other challenge I have is the VCDS cable I have doesn't support high speed logging (turbo mode) so the number of parameters and speed is limited making the resolution less than ideal as most of this happens in the first second or two of take-off.
I'm going to have an independent mechanic have a quick look/drive and see what he thinks but I'll need to have some more firm data / professional opinion that something does need to be rectified to take it back to VW. The local dealer haven't closed the door but have said I'll need to demonstrate the issue for them to be able take it any further.
To their credit they did do some searching on related issues and brought up a TPI 2017165/16 relating to squeaking/creaking noises on full lock but this was more about the ribs of the outer bellows on the steering touching resulting in squeaking/creaking noises and nothing to do with Haldex/diff lock of wheels while turning.
That is a concern.
VW needs to move to an 8 Speed TC and drop these rubbish dual clutch. They sound more unreliable than a rubber band CVT.
Even BMW is dropping the Dual Clutch nonsense.
BMW M to dump dual-clutches, go auto-only within a decade
New 8-speed and 10-speed Automatic Transmissions (Direct Shift-8AT & Direct Shift-10AT) | TOYOTA Global Newsroom
Except that this is not a DSG/dual clutch issue. The 7 speed DQ500 DSG in the Tiguan (since mid-2010) has been a very reliable unit. I have no problems with it apart from maybe not being a massive fan of the factory shift programming.
I think VW has some reasonably good dual clutch transmissions now. The problem is always when you try and make them cheaper and end up becoming less reliable. This is the challenge with making a reliable dual clutch transmission for entry level cars. VW is not the only manufacturer that has had problems at this end of the market.
However back on topic, the issue I've raised in this thread (I believe) is to do with the AWD system engaging during take-off. It's not so much a problem as such with engaging the rear wheels, however it appears that they are being driven in synchronisation. Meaning when you turn a corner it sounds like there's some gripping/slip of the rear tyres on the road.
I'll look to maybe do some more logging to see if I can observe/catch the problem in logging but I suspect this may be a challenge. Otherwise my other option is to set up a camera and try and see if I can record/observe anything from the outside.
