Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Really bad smell when first turn on AC
    Pacific Paradise QLD
    Its in D48806031A9 Heating- Airconditioner Page 132/133
    Workshop manuals for MKII TIguan
    Dec 2018
    Mosman , NSW
    I had something similar with my car, I very strong and offensive chemical smell when I turned on the aircon. It took a while to work out where it was coming from but when I pulled out the pollen filter it was the same smell. It also smelled similar to the washer / wiper fluid that was in the car when I bought it which did not smell nice. Whoever filled up the wiper fluid tank must have used up the whole bottle. I drained and replaced the wiper fluid and also changed the pollen filter to an Aussie foam brand and its all fixed.
    I'm wondering is it possible for water from the windscreen washing to somehow end up soaking in the pollen filter?
    VW Tiguan 162 TSI Highline MY17 Indium Grey DAP Sunroof
    Dec 2019
    I had the exact same problem with my 2015 BMW X1. The problem ended up being a blocked condensation drainage hose that caused water to build and eventually soak the polled filters causing them to go mouldy and hence that smell you get.
    Turn your AC on and run in for about 10 mins. Check to see if there's water from the AC condensation drainage hose. If you don't see any water then chances are, that hose may be blocked or something's preventing the water draining way from the AC unit.
    Thanks to Hillbilly for the workshop manual. As Hillbilly said, check out D48806031A9 Heating- Airconditioner.
    I found the section for the condensation drain on page 160.
    May 2010
    Sorry to revive the thread but I changed my pollen filter and it made no difference. I did it myself and while I was there I checked out the existing filter - no smell or issue with it at all. They seem pretty good quality from factory you could just give it a few smacks in the ground and reuse.
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
    Dec 2018
    S.A.
    Try drying out the system by having the a/c off with temperature and fan dialled to max & running in re-circulate then fresh. Do for all vents and modes. That might kill mould and turn it to powder. Remove & clean the filter again then replace and see how you go. If getting desparate you could try introducing some Glen20 which is mainly ethanol at the fresh intake then use lowest fan in all modes then repeat at full fan. Even blowing air back thru the system might dislodge e.g. a rodent but check with the manual if that can damage e.g. valves/flaps.
    After using a/c (if I remember) I turn it off, raise the temp & blast at hight fan to dry out.
    cars (chronological) Morris850, Morris Mini DeLuxe, Cooper S, Mazda 1500SS, hard times so some old Holden, old Falcon Ute, better times so second hand Lotus Elan +2 (6 weeks, hopelessly unreliable) Chrysler Valiant Charger 770, second hand Datsun 260Z + 2 auto, Mitsubishi Cordia Turbo, Nissan 200SX turbo auto for 20 years(wonderful car burning ZERO oil after 200,000km & no problems when sold.. should have kept it), Toyota GTS 86 auto, now Golf R Mk 7.5 DSG built Aug2018, white.
    Aug 2018
    Issue was fixed during last service they replaced the pollen filter
    Working fine again - especially after these last few days, woah it’s been hot!!!
    2018 Allspace 162TSI R Line
    Apr 2018
    Thumbs down
    Quote Originally Posted by noobatron View Post
    Common trick from Dealers to generate 'work' is to block the condensation drainage hose during a service job
    Once they block the hose, the whole system fills with moisture and stays there when the engine is turned off
    This creates mold and bacteria that then causes a rank smell that infects the whole AC system
    Clearing the drain hose may require some hot days to dry out the system before the smell disapates as well as replacing the cabin filter
    Last SUV dealer wanted to charge me a 'flush and cleaning fee' where they would put a 'cleaning' gas through the system. Cost $200
    Dec 2010
    Helensburgh
    Quote Originally Posted by FastMitch View Post
    That sounds like an urban myth to me. I have had decades of involvement at dealer level and have never seen this done.
