So I thought I'll test this Dragy device, since I've it arrived 6 days ago and it was yet to be used.
Just a quick play around today and no launch control used in these 0-100 results. Ground surface is bitumen and quite flat.
1st run - 6.12sec in "D" + tyres slighty damp (quick wash) curved road.
2nd run - 5.23sec in "S" tyres still damp and span in 1st
3rd run - 4.56sec in "S" tyres now warm.
So far really pleased with those results especially for a big suv. Be really interesting once I actually (gain the courage) to try using LC.
Think I most likely need to invest in some springs, front end just lifts, while the rear digs deep! Once off the line its somewhat fine but a little boaty as the beast just wants to keep going!!
Anyone have any recommendations H&R or Eilbac, or are there others? Definitely a track day for me or dragstrip once this is done, if there are any are coming up?
Oil temps stays around 104-107C normal driving, racemode it peaks to 110C and I don't want it about that! Would definitely need an oil cooler of some sort if any have an recommendation?
Oh btw - I now changed my Turbosmart Dual port DV as it had a faulty solenoid and kept releasing too much pressure or got stuck open so momentarily lost all boost! After 2 of these I decided with there diverter valve instead and got to admit it does sound better and ultimately I've noticed less lag but I could be imagining this... So far so good, it's working well.
