Page 23 of 26 FirstFirst ... 132122232425 ... LastLast
Results 221 to 230 of 253
Thread: Razor80 Stage 3 Allspace R Build
  1. #221
    May 2019
    Melbourne, Vic
    Quote Originally Posted by PDMJO View Post
    Curious to know where you got the work done, and more importantly, if you'd recommend them
    I went to Tripple R Mufflers in Fawkner. https://www.triplermuffler.com.au
    Yes I would recommend them, thought their work to be of good quality and they had the patience to work and understand what I wanted and gave suggestions. I normally read up on reviews before I go and hand over $$$. Because mine was abit complex they charged me $580 but thats including the tail tips too. Another place in Sunshine wanted to charge $270 before doing any custom work. Some more around Melbourne had waiting period of 6-8 weeks or required the car over two business days!
    What are you driving or wanting to get done?
    2018 Tiguan Allspace R-Line - Platinum Grey Metallic
    Stage 3 - Snail IS38 Hybrid Turbo - Etuners Motorsport - 265.5awkw's
  2. #222
    May 2019
    Melbourne, Vic
    Just some sound clips as requested with the Golf R rear muffler and extended pipes.
    Sounds pretty good but has a high pitch drone at low revs or cruising in 7th. Cold start I didnt get a chance to get a clip as it was so loud I left quickly. My wife said it was so loud that the picture frames 3 rooms down were vibrating �� so hence why res has to go back in.
    Dropbox - 20190714_181421.mp4 - Simplify your life
    Dropbox - 20190714_182028.mp4 - Simplify your life
    Dropbox - 20190714_185234.mp4 - Simplify your life
  3. #223
    Feb 2019
    South Africa
    Howsit Razor80.
    With the allspace fid you need to extend the pipe between the dp and the back box?
    Want to do this mk7R mod on my car but not sure if it will fit due to the Allspace being 200mm linger than the std Tiguan
  4. #224
    May 2019
    Melbourne, Vic
    Quote Originally Posted by Boosted_GP View Post
    Howsit Razor80.
    Hi Boosted_GP - The MK7 R muffler will fit straight on with maybe a slight bit of welding to attach it to the existing system. The brackets all line up perfectly so no issues in terms of fitment. You just need to extend the twin pipes each side if you would like them seen through the chrome trim surrounds. If not you could easily have downward firing like the standard Allspace with possibly the same sound effect.
  5. #225
    Quote Originally Posted by Razor80 View Post
    Sounds like an angry Allspace
    But I do get that it may be a little loud now. I'm planning on putting the Golf R exhaust in with the middle resonator (when I get my hands on one).
    May 2019
    Melbourne, Vic
    Yeah angry beast!!
    The mufflers from the Tiguan and the Golf R are almost identical, shape size and even the indentations are the in the same places. Not sure what the internals are like but the only visual difference of course is the extra two outlets. Surely if you can't find one (or borrow the one in the workshop) then drill two holes and weld a pipe to it, probably be the same outcome.
  7. #227
    Oct 2018
    Melbourne, VIC
    Thanks Razor - will keep them in mind when I get around to it.
    Also looking to swap out the exhaust for the mk7 R, but won’t be getting onto it for some time. Looking to stagger the mods over the next couple of years.
  8. #228
    May 2019
    Melbourne, Vic
    After doing my MK7.5 R muffler exchange I've decided to return it to stock look. It was abit too loud for what I intended my build being a sleeper. Looked really good and eventually sounded really nice after a couple of sports resonators being added. Popped on every gear change and had a real deep throaty sound rather then the high pitched drone I was getting.
    So anyway, the stock muffler stays and the MK7.5 R muffler is to be sold. Will bolt up to any MQB Tiguan or Allspace with slight welding or joiner pipe to an existing system.
    If anyone is interested PM me.
  9. #229
    Aug 2018
    It did sound great though with the pops and crackles....Hmmm
    2018 Allspace 162TSI R Line
  10. #230
    May 2019
    Melbourne, Vic
    Quote Originally Posted by iDiesel View Post
    That it definitely had, now no more but the quietness on my long daily drives and the early morning start ups, this now suits. Especially my family and with my neighbours!
    You never know a proper of the shelf system for the Allspace may become available in the next 3-5 years, so might consider it then if I went stage 4 and for track only use.
